PDA
View Full Version : sub advice
URBANRCR
12-15-2005, 11:16 AM
what do you guys think of the alpine type R sub mostlikely a 10" in a ported box.
TBSpyder
12-15-2005, 11:30 AM
With that sub and size, I'd personally go with a sealed box.
Notladstyle
12-15-2005, 12:01 PM
I wouldnt do a ported box unless you have a hatchback. but a single 10 will offer nice crisp bass without weighing you down.
URBANRCR
12-15-2005, 12:23 PM
I GOT A 91 TALON
i meant sealed my bad long day lol.i had jl audio w7 but i want to spend less this time.do you guys know of any problems with the type r subs? thanks
TIM TIM TIM
12-15-2005, 12:30 PM
you can get better with the same money..
URBANRCR
12-15-2005, 12:31 PM
ok im open to suggestions.
TIM TIM TIM
12-15-2005, 01:14 PM
umm kicker cvr.. couple bucks cheaper, must better sounding IMO... mtx 7500, uhh many more, those are just what we carry at Circuit city.... I had 3 type R 10's in sealed boxes, I wasnt really to impressed witht hem
URBANRCR
12-15-2005, 01:24 PM
thanks ill look into them.
djgizmo
12-15-2005, 01:36 PM
Kicker is good, but I'll never buy any gear from them again due to some bad experiences. I disagree about the MTX, but lets not get started about the Alpine vs MTX debate.
URBANRCR
12-15-2005, 02:02 PM
i want something that hits hard i want a 10" i think it sounds better when you just have the fm radio goin.i want something that has at least 300 rms.
GradeA_TireFryer
12-15-2005, 02:15 PM
alpine is a great sub - there is only problem, it likes power - lots of it - to get the most of the driver be sure to put alot of power to it - then it really rocks-
djgizmo
12-15-2005, 02:30 PM
^^ Agreed ^^ Give an alpine type r sub 300+ watts, and it'll get the job done.
URBANRCR
12-15-2005, 03:33 PM
yeah i think ill go with the type r but still look into the kicker cvr . any amp recommendations?
GradeA_TireFryer
12-15-2005, 05:04 PM
I Would Use The Alpine Digital Mono Amp
djgizmo
12-15-2005, 06:54 PM
^^ Yep, I'd go with the 1000 Watter. About $350ish new, 2 Ohms runs @ 1000 watts. (hint hint, you can always turn the gain down if needed)
URBANRCR
12-15-2005, 06:57 PM
ok thanks guys that helped me out a lot.
TBSpyder
12-16-2005, 09:08 PM
I'm not a big Kicker fan. They're sloopy, and a bit unreliable.
If you're going with a Alpine sub, might as well go with an Alpine amp...any mono class putting out 250-500w rms should work well.
Notladstyle
12-16-2005, 10:16 PM
that amps s/n ratio is teh suxx0r
TIM TIM TIM
12-17-2005, 11:46 AM
I didnt mean that kicker or mtx was the best.. I was just really unsatisfied with my 3 type R 10's i used to have... there amps, head units, tv's ect are fucking awesome though..
Miles
12-18-2005, 12:43 AM
ever since alpine added the multi-roll surround to the type r i've liked it.
also i've taken more accurate and faster responding shits than most subs kicker has released. of course i never listen to any booming bass tracks, i'm a double bass man, so quick response/accuracy > spl.
and don't bother with alpine's amps. they may be the best you'll find at best buy or circuit city, but there's much better out there. their s/n ratio is borderline shitty. i assume that's a byproduct of trying to pack too much power into such small packages.
URBANRCR
12-18-2005, 07:50 PM
ok i descided im getting the type r 10" in sealed box actually already got it good deal i just need an amp and more help lol i build motors not stereo systems . i want to know if you buy a new head unit will that make a big difference in the stock speakers in the car or should i replace those also ? is it worth it?
VolvoBoiClw
12-18-2005, 07:58 PM
depending on the ammount of speakers, but for example if you just buy a new h/u that is 51 max * 4 ull run about 17 rms to the speakers, and the speakers will be a little bit more clear depending on the distortion rate on the h.u, but if the speakers arnt bad dont replace them, thats my advice
URBANRCR
12-18-2005, 08:01 PM
im trying to keep weight down thats why the 1 10" but i still want the hard hitting bass and clarity . but i guess ill buy the head unit and give the speakers a try for a few weeks then see what i want to do.
TIM TIM TIM
12-18-2005, 10:26 PM
I am with you, kicker is good for lil john and stuff, which alot of people listen to, therefore its a popular sub... personally im going with mtx (not the best, but with my discount, ill settle) due to the fact that it hits 20213023458 times better then the kicker, just less deep bass
djgizmo
12-19-2005, 12:40 PM
Signal to Noise (S/N) : 90dBA
Which is for the same for the 1000 and 600 watt digital amps.
Miles
12-20-2005, 12:40 AM
well it's still a shitty s/n ratio, whether at 600 or 1000 watts.
Notladstyle
12-20-2005, 02:33 AM
Actually the MRD-m1005 is 85 db according to the owners manual.
djgizmo
12-20-2005, 12:49 PM
I pulled the 90 db SN from the Alpine website.
http://iweb.alpine-usa.com/pls/admn/item_info?p_item_name=MRD-M1005&p_category=40&p_subcategory=105&p_main=10&p_more=y
and
http://iweb.alpine-usa.com/pls/admn/item_info?p_item_name=MRD-M605&p_category=40&p_subcategory=140&p_main=10&p_more=y
respectively
I can only guess that they also UNDER rate their amps as well, simular to Xtant / PPI.
Miles
12-20-2005, 09:42 PM
and
respectively
from everything i've ever seen about them the ratings are pretty dead on.
Notladstyle
12-20-2005, 11:26 PM
and
respectively
Imust have old edition then cuz the side of hte box specs dont match the website!? thats craazy.
djgizmo
12-21-2005, 02:21 AM
hehe, I guess a year to early my friend. should have waited a year ;)
canyouheminow
12-21-2005, 12:33 PM
Low power best sounding sub I ever had was a Polk audio ex 10". The Polk momo's from what I've read and heard are just as good.
Rhino236
12-27-2005, 10:42 PM
the type r is ok ,it will sound best in a ported box
Notladstyle
12-28-2005, 12:17 AM
+1 on the polk ex
ehhh + .5 on the momo subs, they will blow quickly when overpowered
canyouheminow
12-28-2005, 08:11 AM
Any (any descent name brand) monoblock amp, spend a little extra and get a solobaric series.
scrapin_honda
12-28-2005, 10:50 PM
i personally recommend something loud.Lets say one mmats pro diecast12,off a bd1500.
