PDA
View Full Version : HELP I Need Part For Visor Monitor
lilyellowtrk03
12-06-2005, 01:32 AM
i have 2 visor monitors my friend gave me and the 1 is missing the wires that pick into the screen itself if anyone has parts for monitors lmk
Notladstyle
12-06-2005, 11:02 AM
They vary by brand. if its an off brand you might as well open the box up and start tracing wires. It's not that difficult, look for power wires(usually one is leading to a diode and the other will be close by) and the composite input(usually twisted together and one will have a small capacitor nearby.
Record the colors and cut the connector off the end and splice an RCA plug onto it for the video and run power to the other wires. remember for the power that the end with a diode is negative if the line is closest - positive if its on the opposite side... I think... actually double check that been a whille since I took basic components :D
kpr10is
12-06-2005, 12:28 PM
Negative flows through the stripe first.
Notladstyle
12-06-2005, 12:36 PM
ok so I was right, if the wire is close to the bar its negative, if the bar is on the opposite side then its positive.
lilyellowtrk03
12-06-2005, 08:27 PM
sounds tough todo is there any other way
Notladstyle
12-06-2005, 10:53 PM
Since its so complicated I can wire it for you for $50
lilyellowtrk03
12-07-2005, 07:53 AM
you got a contact #
lilyellowtrk03
12-08-2005, 09:06 PM
Notladstyle
12-08-2005, 11:56 PM
I gave you my phone# its a 15 minute job to rewire the cable... seriously
If you IM me I will talk you through it, just send me some pictures of the box and get your solder ready.
