View Full Version : idle problem
over da bridge
11-29-2005, 05:21 PM
my galant idles high than will go right back down an then up again sounds like its purrin anyone kno whats wrong lmk thanks tobey
Ender.
11-29-2005, 05:40 PM
Welcome to idle surge.
Is this a vr4? If so check the BISS Screw located on the throttle body, it might just need to be adjusted. Im not sure if n/t have them as well.
Other problems might be but are not limited to, the ISC as well as the ECU having leaky caps.
over da bridge
11-29-2005, 05:46 PM
no its a gs
Ender.
11-29-2005, 05:48 PM
no its a gs
Well look for what I described and see if that helps any...
over da bridge
11-29-2005, 05:54 PM
ok will do thanks ill let you kno if it helps
supertalon
11-30-2005, 01:55 PM
anyone know about that problem on a 93 talon?? i have the some problem. any solutions?? sorry to ask this on YOUR thread ODB : )
over da bridge
11-30-2005, 03:02 PM
lol its all good if you have the same problem no need to say sorry
Ender.
11-30-2005, 05:02 PM
http://www.plymouthlaser.com/biss.htm
Theres some more info about the BISS. Also check for vacuum leaks. There are so many things that can cause Idle Surge, if you do a search on any DSM forum there will be many diagnosis's for it. Good luck in tracking down the problem.
russellbeermann
12-06-2005, 08:53 PM
vacuum leak, check the gasket for your intake mani. this was my problem in the past
Jordan Y.
12-07-2005, 12:37 PM
Any leak after the MAF will cause that problem. Check all your vacuum hoses, the intake pipe, proper function of the FIAV, intake mani gasket, injector seals. Then go after the electrical- properly set your idle, test the ISC.
vBulletin® v3.6.10, Copyright ©2000-2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by
vBSEO 3.2.0 RC5
