View Full Version : overheating 2g rs-t
mitsu420aT
11-25-2005, 12:53 PM
i have replaced the thermostat 2wice and the radiator has been back flushed. it only gets hot when i start to build boost and then when i drive normaly again it go back to normal.any other boosted 420a have this problem or heard of it. up for suggestions!?!?!
hunntyr
11-25-2005, 02:15 PM
Check your ECT switch (engine coolant Temp). its a little switch right underneath the thermostat housing. It might be corroded and throwing the sensor off. I replaced mine in my boosted 420A and that solved the overheating issue. Also check for cracks in the housing itself where any leaking could be spotted.
mitsu420aT
11-25-2005, 02:58 PM
thanks for the info, i have indeed looked for any cracks in the housing there a re none due to the fact that i have just put a new one on because i broke the original one while changing the org thermostat.i will change the switch again due to the fact that some times you get bad ones.
RB240Mike
11-25-2005, 03:05 PM
Lol I had an overheating problem last night... my radiator cap blew off while I was driving LOL it was kinda funny although I had to get a cop to give me a ride home lol. You do have an intercooler though right... it's not hot piped is it?
mitsu420aT
11-25-2005, 03:13 PM
i do have a inetrcooler but i was hot piped for a while. i still have the problem but not as bad as it was while hot piped
RB240Mike
11-25-2005, 03:31 PM
um well if you heat wrap the intercooler piping it will trap that cool air... that'll make it run a little cooler although it won't look that good.
GsEclipse02
11-27-2005, 11:15 PM
or ceramic coat it ...looks and does a better job...
vBulletin® v3.6.10, Copyright ©2000-2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by
vBSEO 3.2.0 RC5
