PDA
View Full Version : Need help putting CD player in Del Sol, T-N-C
Lincoln
11-20-2005, 01:33 PM
Trying to put new CD player in Del Sol.
No blown fuses and I am trying to avoid running new power wires to the CD player. The CD player is not powering up. Anyone willing to come take a look at it hit me up.
Lincoln
813-310-3912
Notladstyle
11-20-2005, 01:42 PM
Lincoln
813-310-3912
where are you located and what things have you tried already?
Lincoln
11-20-2005, 01:46 PM
I am in the Waters and Sheldon area of Tampa.
I unhooked the old broken stereo and hooked up the wires to the new one. It was a straighted forward replacement, but it does not power up. I checked the fuse for the stereo and it is fine. The clock in the dash is not working either.
Notladstyle
11-20-2005, 02:50 PM
I had the same problem in an integra with the clock not workin.
do you have an ohms meter? I can tell you the steps to fix it if you have one.
Lincoln
11-20-2005, 02:53 PM
I had the same problem in an integra with the clock not workin. do you have an ohms meter? I can tell you the steps to fix it if you have one.
No, I don't have an ohms meter.
GradeA_TireFryer
11-20-2005, 04:01 PM
the fuse under the hood controls the memory wire and clock
integralsgreen
11-20-2005, 04:09 PM
did you use a harness or did you cut the factory wires?
Lincoln
11-20-2005, 04:29 PM
I am using a harness.
GradeA_TireFryer if you ever go to QS&L or Shennanigans let me buy you a drink. I found a burnt 7.5 amp fuse in the engine compartment, replaced it, and now everything works. It is strange that there are no markings on the fuse box in the engine compartment telling what each of the fuses are for. I never thought about there being a fuse in the engine compartment for the clock.
Notladstyle
11-20-2005, 05:38 PM
Damn, they were inside on the teg ;)
GradeA_TireFryer
11-20-2005, 10:11 PM
There Is A Fuse Box Also On Teg's In Engine Comp (layout In Owners Manual)
I Work On A Teg With A Type R Motor Swop And It Had 13 Blown Fuses - Nothing Worked
When I Was Done Every Thing Worked - But The Dumbass Did Not Want To Pay Me To Install Radio - Next Day He Was Back He Popped 3 More Fuses And Finally Let Me Install Radio And No More Bad Fuses....
I Dont Understand Poeple - Spend Thousand Of Dollars On Equiptment But Wont Pay Someone To Make It Work Correctly.. This Fool Lived With All Those Blown Fuses For Over 2 Months, It Was His Daily Driver
integralsgreen
11-20-2005, 10:41 PM
F***ING RETARDS
SmokinS13SR20
11-20-2005, 10:49 PM
F***ING RETARDS
+1
Notladstyle
11-20-2005, 11:19 PM
:overkill::owned2:
spoonfedcivic
11-27-2005, 10:58 PM
if u have the lil piece under the dash it flips down it should have a clear plastic card type thing there it tells u all the fuse and what they are and what they control but i was gonna tell you i will help i also have a sol and i do all my own audio
Notladstyle
11-28-2005, 02:06 AM
whoa bud, you are a week or so late :o
spoonfedcivic
11-28-2005, 11:45 AM
i jus saw the post yesterday mybad
