PDA
View Full Version : FS: t2 shell and all engine stuffs w/ turbo
rx7mpguy84
11-08-2005, 01:06 PM
Rotors per stamped B = $150 a peice
Housings = $100 for both (only works on a 12a or rx2 or 3 or truck)
Irons = $150 a peice
T2 shell with great brakes and 17" rims with new tires s5 tails = $700
UIM=50
LIM=50
Turbo t04 htrim hybrid = $300 with manifold and dp ported wg
Race exhaust port stencil = $15
Bridge port stencil = $20
Stock injectors and rails = $45
T2 wiring harness = $80
intercooler, modified w/ hoses = $50
RA apex seals and springs, barely used for 10 seconds = $100
Oil rings and seals with springs $30 for whole set
Side seals with springs = $30 whole set
Jacobs electronics Spark controller (same as MSD 6a) $100
Shifter stock = 15
Turbo transmission good working no problems = 200
Eccentric shaft = $30
Drive shaft = $50
BOV with custom made flange stage 3 = $65
Flywheel, just had it shaved = $50
Stage 6 3 puck clutch with stage 2 mazdaspeed pp = $100
please pm me for pics, with your email or aim me at pfcmpguy84
thanx
everything is in the new port richey area
TOBYOTA
11-08-2005, 09:08 PM
Hi im toby. do you still have the drive shaft and the clutch?? Im also interested in some of the other stuff. thanks
rx7mpguy84
11-08-2005, 10:37 PM
yes clutch and drive shaft are still available. send me an email and ill send you pics, thanx
rx7mpguy84
11-09-2005, 01:50 AM
$600 for shell with rims, im so losing out, $110 per rotor, $110 per iron, $100 for pair of housings in good condition ported (gxl se only) Turbo w/o mani or dp (250) w/ mani and dp (300) Jacobs electronics spark controller (pretty much msd 6a) $85, everything else same price. buy me now. im desperate to get this out
rx7mpguy84
11-09-2005, 02:45 AM
i will tow shell anywhere u want. as long as its within reason. thanx
Rotary Buddha
11-09-2005, 08:20 AM
so whats the detail on the dp and mainfold, is it stock? if not who made it and what size is it? manifold flange? etc........
rx7mpguy84
11-09-2005, 10:37 AM
its a stock hybrid, stock hot side with a to4h trim cold side. The dp will fit a regular turbo same with the manfiold, i have a 2.5" dp, idk who makes it, i got it for like $80 and used it for less than a year, 02 sensor is still like new.
rx7mpguy84
11-09-2005, 12:37 PM
ebaying most of the motor stuff hopefully tomarrow! buy it before i resort to ebay. thanx
rx7mpguy84
11-09-2005, 01:10 PM
its a racingbeat downpipe, $90 new, $50 for mine used 1500 miles and has new 02 sensor.
Rotary Buddha
11-09-2005, 06:23 PM
s4 turbo? if so does it still have that side scroll thing still? when you say to4h do you mean a to4 with h trim compressor wheel?
FC_V8
11-09-2005, 08:49 PM
???pm'ed u..
