PDA
View Full Version : FS: T2 rx7 1987 t04 turbo Bridge Ported $2k
rx7mpguy84
11-04-2005, 08:24 PM
up for sale really cheap, my t2 rx7. Was a 1987 se, but completely swapped everything out for t2. even has s5 interior (burgandy). Turbo is a hybrid rebuilt t04 h trim. Exhaust ports have been street ported and im in the process of bridge porting the irons. Has a jacobs electronics ingition set on there. T2 fuel pump, stock 550cc injectors. t2 hood is shot, due to not locking it down while in tow.
Car currently does not run, has been rebuilt, but due to using the pre 85 housings, the rotor housings leaked coolant to the combustion area, no damage was done, but the rotor housings will have to be replaced, has RA seals and RA apex seals, FD corner seal springs. The only thing this car needs is a new set of rotor housings and upgraded fuel system and youll have a 11 second car, (tuning of course) Car is gray, check my garage for pics. Price is 2k firm, I refuse to sell it for less becuase the turbo balancing and rebuilding and motor rebuilt equaled that much.
Reason for sale is because im moving and i have to fix my motorcycle, and cant afford to keep dumping in the motor anymore, I could put it back together and sell it easily for 3500 or 4000, so get it now for 2k dollars. 2k more and itll be worth about 7 or 8k according to autotrader sales ive seen. let me know if anyone is intrested.
Also to let you know, the motor is apart, im recleaning all the parts and getting it ready so that all you have to do is either fix up the rotor housings or get new ones.
rx7mpguy84
11-04-2005, 09:55 PM
also it comes with 17" rims and tires 215/40/17 nankang. Worth $500 just for the rims and then $250 for the set of tires. Also has a big ass stage 3 BOV, can handle 35psi of boost. Also has a 2.5" aftermarket down pipe, no exhaust after that, i was going to do a custom job and have it come out of the right side before the back tire. Wastegate is ported. comes with optima redtop. If i remember anything else ill post it.
rx7mpguy84
11-07-2005, 08:39 PM
if no one wants to buy the whole thing ill sell the parts. heres the price list, firm
Rotors per stamped B = $150 a peice
Housings = $100 for both (only works on a 12a or rx2 or 3 or truck)
Irons = $150 a peice
T2 shell with great brakes and 17" rims with new tires s5 tails = $700
UIM=50
LIM=50
Turbo t04 htrim hybrid = $300 with manifold and dp ported wg
Race exhaust port stencil = $15
Bridge port stencil = $20
Stock injectors and rails = $45
T2 wiring harness = $80
intercooler, modified w/ hoses = $50
RA apex seals and springs, barely used for 10 seconds = $100
Oil rings and seals with springs $30 for whole set
Side seals with springs = $30 whole set
Jacobs electronics Spark controller (same as MSD 6a) $100
Shifter stock = 15
Turbo transmission good working no problems = 200
Eccentric shaft = $30
Drive shaft = $50
BOV with custom made flange stage 3 = $65
Flywheel, just had it shaved = $50
Stage 6 3 puck clutch with stage 2 mazdaspeed pp = $100
rx7mpguy84
11-07-2005, 10:43 PM
RA apex seals and springs, barely used for 10 seconds -pending sale
FD corner seals, brand new, set of 12 -pending sale
Corner seals = -pending sale
Oil rings and seals with springs -pending sale
Side seals with springs -pending sale
Stage 6 3 puck clutch with stage 2 mazdaspeed pp -pending sale
Optima redtop -pending sale
Stock injectors and rails -pending sale
Hurry up and buy from me people.
rx7mpguy84
11-08-2005, 12:30 AM
http://photobucket.com/albums/b3/zx636mpguy84/?action=view&current=100_5218.jpg = intake system = $40 includes afm and filter and pipeing
http://photobucket.com/albums/b3/zx636mpguy84/?action=view&current=100_5217.jpg = stock fan $20
http://photobucket.com/albums/b3/zx636mpguy84/?action=view&current=100_5219.jpg = intercooler (bov is not included)
http://photobucket.com/albums/b3/zx636mpguy84/?action=view&current=100_5215.jpg = bov
http://photobucket.com/albums/b3/zx636mpguy84/?action=view&current=100_5210.jpg= optima redtop
http://photobucket.com/albums/b3/zx636mpguy84/?action=view&current=100_5208.jpg = Rotor housing pic 1
http://photobucket.com/albums/b3/zx636mpguy84/?action=view&current=100_5207.jpg= Rotor housing pic 2
http://photobucket.com/albums/b3/zx636mpguy84/?action=view&current=100_5205.jpg = Rotor housing pic 3
http://photobucket.com/albums/b3/zx636mpguy84/?action=view&current=100_5204.jpg = Rotor housing pic 4
all of those were rear rotor housings
http://photobucket.com/albums/b3/zx636mpguy84/?action=view&current=100_5214.jpg = 3 puck clutch
http://photobucket.com/albums/b3/zx636mpguy84/?action=view&current=100_5212.jpg= 3 puck clutch pic 2
http://photobucket.com/albums/b3/zx636mpguy84/?action=view&current=100_5201.jpg alternator t2, $40
http://photobucket.com/albums/b3/zx636mpguy84/?action=view&current=100_5197.jpg= LIM comes with no emssions and block off plates
http://photobucket.com/albums/b3/zx636mpguy84/?action=view&current=100_5194.jpg = seals for rear rotor
http://photobucket.com/albums/b3/zx636mpguy84/?action=view&current=100_5193.jpg= seals for rear rotor pic 2
http://photobucket.com/albums/b3/zx636mpguy84/?action=view&current=100_5192.jpg = side seals for rear rotor
http://photobucket.com/albums/b3/zx636mpguy84/?action=view&current=100_5191.jpg = mazdaspeed pressure plate
http://photobucket.com/albums/b3/zx636mpguy84/?action=view&current=100_5190.jpg = close up of mazdaspeed signia on pp
http://photobucket.com/albums/b3/zx636mpguy84/?action=view&current=100_5185.jpg = underside of pp
http://photobucket.com/albums/b3/zx636mpguy84/?action=view&current=100_5184.jpg= flywheel, needs sanding 3000 grit, but was shaved not even 3 months ago not used thats why it looks like it does.
http://photobucket.com/albums/b3/zx636mpguy84/?action=view&current=100_5183.jpg = oil pump, $20
http://photobucket.com/albums/b3/zx636mpguy84/?action=view&current=100_5182.jpg= t04 turbo moer pics soon of what old one looked like
http://photobucket.com/albums/b3/zx636mpguy84/?action=view&current=100_5181.jpg= endplate
http://photobucket.com/albums/b3/zx636mpguy84/?action=view&current=100_5180.jpg= endplate pic 2
http://photobucket.com/albums/b3/zx636mpguy84/?action=view&current=100_5179.jpg= endplate pic 3
http://photobucket.com/albums/b3/zx636mpguy84/?action=view&current=100_5178.jpg = rear rotor
http://photobucket.com/albums/b3/zx636mpguy84/?action=view&current=100_5177.jpg = rear rotor 2
http://photobucket.com/albums/b3/zx636mpguy84/?action=view&current=100_5176.jpg= rear rotor 3
