View Full Version : getting a deck installed
psychx
11-02-2005, 08:20 AM
planning on having a new in-dash cdplayer (deck) installed, should i just go to circuit city?
im not sure if the speakers work (contacted original owner a few minutes ago but im not sure if ill get a response today), how can i check this? can circuitcity do this? i dont want to have to pay any extra money than i should have to, but i thought circuitcity did free install which is nice, and i think its got warranty
GradeA_TireFryer
11-02-2005, 08:50 AM
Both Cc & Best Buy Offer Free Deck Installs - Labor Only
You Still Will Need A Wire Harness / Dash Kit (bb Is Cheaper)
Speakers Can Be Tested If They Are Connected - Wont Be Able To Tell You If They Are Good Until They Are Listened To.
Notladstyle
11-02-2005, 09:34 AM
Take an ohms meter to the harness and look got 4ohms on each + - point for the speakers. Generally, if you can get to the harness you dont need BB or CC to install your stereo though. Just let the pros handle it for you.
On another note, dont pay ~$40 for the kit & harness either.
psychx
11-02-2005, 10:21 AM
this harness? (i have a pioneer deck in there currently)
http://www.circuitcity.com/rpsm/oid/72058/rpem/ccd/productDetail.do
i think thats what is messed up... i have gotten to this before (taking dash apart a little bit), and i can do it again, so should i just buy this and try to replace it? i have powered my deck up before, but i unplugged the power since the wiring was screwy, i didnt want to mess anything up for any reason. is it relatively easy to replace this wiring harness?
kpr10is
11-02-2005, 11:04 AM
No, if you currently have a Pioneer deck in there, and it was installed correctly, you wont need any parts to install a new radio.
So your current Pioneer deck turns on but no speakers play?
P.S. Theres nothing wrong with a Circuit City install...but Id recommend not going to the Spring Hill store. I havent heard great things about their installers(this coming from a fellow Circuit City installer). Go to the clearwater store, or AVE Audio. Or DIY is always good.
psychx
11-02-2005, 12:01 PM
well the pioneer deck appears to work fine, and i just heard back from the previous owner that the speakers work fine, but when i tried hooking it up (he had just thrown it in, it wasnt hooked up, he had a diff one in there), it didnt fit right ot anything, the wiring was all messed up. so i was thinking maybe i have to get the wires for the deck
GradeA_TireFryer
11-02-2005, 12:40 PM
i will fix it for $20
psychx
11-02-2005, 12:47 PM
i think i can do it i just need to know if thats what ill need
kpr10is
11-02-2005, 01:22 PM
is the factory wiring harness in the dash?
psychx
11-02-2005, 01:24 PM
what does it look like? ill take a look inside
psychx
11-02-2005, 01:35 PM
theres a plastic clip with the power wires and a bunch of cut wires coming out of it
the clip can attatch to the head unit
theres also a bunch of other wires
psychx
11-02-2005, 01:53 PM
kpr10is
11-02-2005, 03:30 PM
The shape of your factory harness
http://www.audiovideodeals.com/images/71-1771.jpg
If installed correctly, there should be a harness like below that the pioneer deck wires connect to, that plugs directly into your factory one.
http://www.ebizenterprise.com/ProductImages/images7/70-1771.jpg
psychx
11-02-2005, 04:15 PM
i think im missing my factory harness?? :(
GradeA_TireFryer
11-02-2005, 04:35 PM
still do it for $20
psychx
11-02-2005, 07:18 PM
ok i got it setup, it powers up, everything is working, except this:
i only hooked up the 2 back speakers, but only one of them is working, they appear to be hooked up correctly and i was told it works, any ideas? the other works great
Notladstyle
11-02-2005, 07:31 PM
stop money mongering tirefly :p
psychx - run new speaker wires.
psychx
11-02-2005, 07:43 PM
you think it could be the speaker wire? cause im pretty sure it should be working... i believe that is the speaker that has a bunch of wire problems tho, i want to get someone to look at it tho, it seems like something might be messed up in the connections to the speaker, the positive and negative connectors but im not sure
i really wanted to get this done tonight lol, ive gone so long without audio (like 2 months)
Notladstyle
11-03-2005, 10:41 AM
pull the speaker that is working and plug it into the plug from the one that isnt. Any sound? if not then run new wires and save yourself the headaches. If you get sound then you know its a bad speaker. Go to walmart and drop $30 on a pair of el cheapos and they will still sound better than stock, or alternatively, walmart also has OEM speaker replacements for 10$
SSpiro
11-04-2005, 08:36 PM
still do it for $20
I got 18.90 on it.
:D
psychx
11-05-2005, 01:41 PM
i got it all working but now it seems like maybe the harness from the deck is loose or something, sometimes sound cuts out completely, but the deck keeps playing the song. all speakers are wired and crimp'd correctly
Notladstyle
11-05-2005, 07:43 PM
solder is ur friend
CHUPA_CABRA_2.0
11-09-2005, 01:25 PM
just an idea can you post a pic of the situation the thing is unless someone goes in there or atleast if we can see we're all more than happy to help
Content Relevant URLs by
vBSEO 3.2.0 RC5
