View Full Version : its possesed
kapenna
10-27-2005, 05:51 PM
its not my neon its my tiburon. turned the car on and i have head lights and fog lights. but my gauge lights, hazards, blinkers, tails, shifter light on center console, power windows, wont work. ALL FUSES ARE GOOD. this has happened before and i didnt find the problem but 2 days later everything started working again. im wondering if anyone knows anything?
Josiah
10-27-2005, 06:31 PM
sounds like a short to me, or maybe a bad relay?
macncheese
10-27-2005, 06:54 PM
get out the wiring diagram and find the ground for that circuit. i'll bet a dollar that your ground is causing the problems.
tony
hiwayhuntr
10-28-2005, 01:46 PM
sounds like a short to me, or maybe a bad relay? ++++1
kapenna
10-28-2005, 05:17 PM
ok thanks, would that cause it to come off and on? obviously if the ground is loose but wouldnt it jump of and on more frequently? i have to get a manual. i will keep you posted.
hiwayhuntr
10-28-2005, 05:20 PM
the relay might have a bad conection or try the grounds and also look at the back of the fuse pannel to see if any wires have come out or are loose.
Josiah
10-28-2005, 05:29 PM
unfortunately shorts and bad grounds are notoriously hard to track down...get a voltmeter and good luck
kapenna
10-28-2005, 05:35 PM
yeah if i cant find it i will take it somewhere an have them get the head ache
Content Relevant URLs by
vBSEO 3.2.0 RC5
