View Full Version : 660cc Injectors, 1g 91 E-Prom Chipped ECU
660 Injectors: 200.00
E-Prom ECU: chipped for GM Mas, 660's...175.00
Thanks, Chet
860-459-8689
VWFREFF
10-26-2005, 01:46 PM
would those injectors be sufficient enough for a t4 57trim (p trim wheel) at like 23 lbs.?if so i will probably pick them up from you.
Ian MMF
10-26-2005, 01:57 PM
Yup more then enough. Just make sure you got something to tune them with and make up for the compensation of running larger injectors.
Frankie Figs
10-26-2005, 02:09 PM
is there anything else on that chip?
bigkert
05-11-2006, 07:36 AM
Chet it's Kert. Do you still have that ECU and whats the cost ??
awdsal
05-11-2006, 12:21 PM
did you look at the date
Jordan Y.
05-11-2006, 02:36 PM
Old
Content Relevant URLs by
vBSEO 3.2.0 RC5
