PDA
View Full Version : install guru`s *input*
BrewPuBeaver
10-24-2005, 08:28 PM
okey just order`d my front speakers and the 600x4 for the speakers and the 1500x1 at 1 om. but i have a 4 om sub so it will be a 600x1.
i got the diamond s600s hex speakers with cross overs and silk tweets for the front
diamond m6 with crossovers and aluminum tweets for the rear
diamond 600x4 for the speakers and 1500x1 for my sub. diamond D6 12 sub.
i would like to mount both of the amps some how on the rear seat. or on that black peice of plastic. i have a rear strut (http://forums.nasioc.com/forums/showthread.php?p=11484850#) bar. so i might be able to brace off of that. buti want it to look clean. any thoughts...
i also have a custom slot ported box. all rounded edges and all that stuff
kpr10is
10-24-2005, 09:02 PM
Good luck mounting both those amps on the back seat. That D6 1500.1 isnt small.
Fuck trunk space, do something like this...my buddys maxima that I installed everything in, soon to be finished
http://www.tamparacing.com/photopost/data/500/medium/IMG_0300.jpg
BrewPuBeaver
10-24-2005, 09:11 PM
not to say that looks bad. but just not what i am looking for...
Notladstyle
10-24-2005, 09:21 PM
Hes right about space. A false floor is actually a pretty good choice. Not to mention you will probably need to fan cool them and a false floor will provide the means to circulate the air.
but im pretty sure if you sacrifice trunk space and mount them both at an angle they will fit against the back seat.
URBANRCR
10-24-2005, 09:52 PM
good luck man its not gona be easy.
BrewPuBeaver
10-24-2005, 09:57 PM
was thinking of having Audio itch or Cue Auto restyling do the work...
URBANRCR
10-24-2005, 10:02 PM
let the pros do it always a good idea .
BrewPuBeaver
10-24-2005, 10:03 PM
i figure it is the best way. but i want to have an exzact idea of what i want
URBANRCR
10-24-2005, 10:08 PM
yeah it always helps i usually put them in a ghost box or i put the subs in the spare tire space and put the amps on the side of the trunk also put grills or a piece of lexan over the subs.
BrewPuBeaver
10-24-2005, 10:12 PM
i only have 1 sub. it is a diamond D6 12inch. and i have a custom box. but it is really big. but it sounds really good.
i just want something that looks really clean and is functional.
URBANRCR
10-24-2005, 10:34 PM
well i wish you luck.
BrewPuBeaver
10-24-2005, 10:41 PM
thanks man
