03 ranger door panel
i want to replace the door speakers, how do i get the door panel off? iv never tryed to take it off just wondered if anyone has done this b4....thnx
http://www.bassheadsent.net/
remove the trim piece around the handle 2 phillips or 7mm i forget. pop it off should be one more behind there and maybe one on the bottom rear of the panel. once screws out panel pulls straight up not out.
Look around the handle on the inside of the door to pop the door open. There are 2 screws rite under the handle, take them out. Pull the plastic trim off that goes around the handle. Grab the bottom of the door and pull the door straight out on the bottom only. After the whole bottom half of the door is popped off, pull the rest of the trim straight up.Make sure your windows are down. If you have power, unplug the plugs for the switches
