View Full Version : royal purple vs motul oil
fadedSTi
09-29-2005, 12:50 PM
i tried both oils out and i like the motul better. the royal purple seemed to be thinner and burn a little quicker. i put the motul back in it today and it seems smoother than the royal purple. anyone else tried these oils out? what was your experience with the different oils?
platinm
09-29-2005, 12:57 PM
I use RP, but have used Motul. Both are good. I don't know if one is better than the other.
HKSWRX
09-29-2005, 01:25 PM
I am having a problem with Mobil One burning too quick, I'll have to check the Motul out, which weight do you run?
fadedSTi
09-29-2005, 02:59 PM
i have heard that about mobil 1 oil. does burn pretty quick. i use 5w-30
HKSWRX
09-29-2005, 03:14 PM
i had a friend tell me to try mobil one 15w 50, he says a heavier weight wont burn as fast
M249SAW
09-29-2005, 03:28 PM
Yes but more friction loss and worse gas mileage with a thicker oil.
fadedSTi
09-29-2005, 03:44 PM
yeah thats a bit heavy. heaviest i would go would be 10w30
HKSWRX
09-29-2005, 04:10 PM
Thanks for the info
Alizarin
09-29-2005, 05:06 PM
John, to be fair, your car is visibly smoking. I do not think that oil brand will change that, or going to a heavier weight.
As for weights, I run Mobil 1, 5w30 in the winter (like, the 3 months it gets "cold" down here) and 10w30 all other times. I'm going to try RP or Motul for my next Dragon trip (after the one coming up) and see if I burn less over the course of the trip.
BrewPuBeaver
09-29-2005, 05:08 PM
john yea i second the smoking tail pipe. you said you burned 5 qt`s over 3000 miles.
you have something wrong with your car. and i know masto said it was normal... bullshit
fadedSTi
09-29-2005, 05:09 PM
what color smoke we talking about here? black, blue, white?
BrewPuBeaver
09-29-2005, 05:11 PM
all of the above, lol
Alizarin
Blue... oil smoke.
fadedSTi
09-29-2005, 05:12 PM
Blue... oil smoke.
thats called dying motor smoke, ouch. very sorry to hear.
HKSWRX
09-29-2005, 05:22 PM
my car doesn't smoke that bad, especially lately. and I think I may have the same oil levels for a while, im gonna check it tonight.
BrewPuBeaver
but he has 240 to the wheels.....
fadedSTi
any blue smoke is bad. meaning its burning oil. rings arent sealing very well
HKSWRX
09-29-2005, 05:27 PM
I had mastro check it out right before the warranty was over, they told me everything was great on it. I have had a wee bit of smoke for well over a year now. I think its bill at mastro said a little oil makes it past the oil rings and thats normal.
BrewPuBeaver
09-29-2005, 05:29 PM
dude, i would say you have a lot more than a wee bit...
but if it runs stong and you like it. thats your car
fadedSTi
09-29-2005, 05:32 PM
+1
HKSWRX
09-29-2005, 05:36 PM
Well since I put in 10w30 oil (from north carolina to here) I haven't had a problem, I honestly think it was the weight of the oil, plus I have a bad habit of pedal to the metal. (Bill told me when you floor it some oil sneaks by)
fadedSTi
09-29-2005, 05:40 PM
only one fur sure way to tell. compression and leakdown test. i put out 23.5psi and no smoke:dunno:
BrewPuBeaver
09-29-2005, 05:46 PM
one question
how do you tell your car isnt smoking when your in it?
HKSWRX
09-29-2005, 06:00 PM
:dunno:
QuickOne
09-29-2005, 06:28 PM
Yeah thats what they said about my old car when it started using 1qt per 1k. Then they said comp of 125 was normal too....... :roll: :roll:
I just thought thats cause they tuned it but now? Jonh, did they tune yours too?
fadedSTi
09-29-2005, 06:30 PM
ive talked with HKS about it and it looks like he may do a compression and leakdown test to get real results. that will tell all.
BrewPuBeaver
09-29-2005, 06:31 PM
seems like a lot of stuff has happend to you Brian. i understand why you are so bitter now
HKSWRX
09-29-2005, 06:32 PM
oh lawdy don't tell me that :nono:
fadedSTi
09-29-2005, 06:37 PM
you dont even want to open that can of worms.
B- you dont open them either ;)
HKSWRX
09-29-2005, 06:41 PM
Yes they tuned my car. :(
QuickOne
09-29-2005, 06:42 PM
Yeah if anyone needs the down low feel free to PM me. :D
BrewPuBeaver
09-29-2005, 06:43 PM
you have just filled your inbox
QuickOne
09-29-2005, 06:45 PM
Well then I would bet that what ever tests they perform will come out "normal" ;)
QuickOne
09-29-2005, 06:50 PM
I hope I haven't been bitter twords you? I don't think I would call it that anyway. I have been around long enough to know better and I don't take any BS. Certianly not from some kids. (not reffering to any of you guys)
BrewPuBeaver
09-29-2005, 06:53 PM
i was just giving you shit old man
How 'bout we let him watch the compression test and leakdown test being performed so he can see the readings we are getting and then we can pull out the service manuals to see what the proper tolerences are for each test and compare them to the results. Then he can see if it comes out "normal" for himself. Anyone who is interested in getting a compression and/or leakdown test performed is more than welcome to watch it being performed and see the results for themselves.
On a turbo car oil can get into the combustion chamber from some other places than just getting past the rings (and all cars allow a very small amount of oil to get past the rings on each stroke of the piston, this is normal)...it can also come from the turbo itself (bad internal seals from the oil passages) and through the PCV system (clogged or stuck PCV valve) to name a few. So you can have a car that passes the leakdown and compression tests yet still burns oil.
...also on the turbocharged 2.0 and 2.5 liter engines, Subaru's acceptable oil loss is up to 1 quart per 1,000 miles. The harder you run it...the quicker it'll burn it. From personal experiance RP dissappears much, much more quickly than any other oil I've seen.
Click here for info regarding the compression test, and acceptable tolerences. This is from the service manual for the 2004 Impreza WRX & STi 2.0 & 2.5 DOTC Engines (Dual Overhead, Turbo Charged). (http://www.subaruchallenge.com/Wills/04CompTest.pdf)
Standard = 142psi - 171psi per cylinder
Limit: no less than 128psi per cylinder
Difference between cylinders: Less than 7psi
Click here for info regarding the engine troubleshooting, see Section #9 - "Excessive Engine Oil Consumption" (Page 4) for the possible causes as per the service manual for the 2004 Impreza WRX & STi 2.0 & 2.5 DOTC Engines (Dual Overhead, Turbo Charged). (http://www.subaruchallenge.com/Wills/EngineTroubleshooting.pdf)
Possible causes include:
Intake System: Loosened or cracked PCV hose, defective PCV valve, Loose oil cap.
Compression: Defective Valve Stem, worn or stuck rings, cylinder or piston. (These would be ruled out by a passing compression test).
Lubrication system: Loosened oil pump attaching bolts, defective oil filter o-ring, defective crank seal, defective valve cover gasket, loose or defective oil drain plug or gasket, loose oil pan fitting bolts or defective oil pan.
QuickOne
09-29-2005, 11:50 PM
Well like I said here^^^
And like you said hereVVVVVV
The thing speaks for it's self. I never ment to imply that any thing would be fudged. But My results where 125/135 which fails on both counts and I was FLAT OUT TOLD THAT WAS NORMAL AND WITHIN IN TOL. That and burning 1qt per 1k.
Oh yeah then my car was sold without that being remedied. Oh well I'm just a disgruntled former employee :oops:
Oh and before anyone flies off here; I have the copies of the test results as they came off the service dept printer.
QuickOne
09-29-2005, 11:53 PM
Oh and sorry John lets get BOT, please. :D
Alizarin
09-30-2005, 01:39 AM
This is true too. Running the Dragon for a weekend will cause my car to burn about a quart of oil, what with all that engine braking and high rpm running.
I really didn't mean to start a big whoopdie-doo over John's smoking car! :-o
HKSWRX
09-30-2005, 02:25 AM
:lmao: @ the whoopdie-doo
Opie: How much for the compression test, ME THINKS you should do it for free to settle my troubled thoughts...
If I owned a compression gauge I would do it for free for you myself... :D
The tech's aren't so charitable :lol: , according to the Mitchell time guide here are the charges for compression tests:
2.0L - $192.00 (2.4 hours)
2.5L - $96.00 (1.2 hours)
add a leak-down test for either motor for $40.00 additional.
fadedSTi
09-30-2005, 09:24 AM
not bad pricing at all. thats a good deal john. will give you a understanding of whats going on in there.
thanks for taking care of that issue for me yesterday ;) :lol:
HKSWRX
09-30-2005, 09:47 AM
192.00 Good Lord Thats Alot Of Money! ;)
fadedSTi
09-30-2005, 09:51 AM
how much is it if you throw a rod though?;)
HKSWRX
09-30-2005, 10:00 AM
when your right, your right.
cray390
09-30-2005, 11:28 AM
10k +
Content Relevant URLs by
vBSEO 3.2.0 RC5
