View Full Version : List your 60' time and suspension mods
plan Z
09-22-2005, 03:44 PM
thought it would be interesting to see what 60' times you all are getting and what kind of suspension mods and tires.
my best so far
1.697
S/T shocks/struts and Sprint springs
Poly bushings (sway bars, end links, torque arm, and tranny)
Nitto 555R 245/45/16
ps-can i get some rep points for starting a thread since i never do and dont have any:)
Skittle
09-22-2005, 03:47 PM
2.0
Stock suspension
215/40's
$hawn
09-22-2005, 04:20 PM
1.704.....All stock except for FRPP lower springs( not the best for drag launches:)).sway bars and all.
Duceanahalf
09-22-2005, 05:19 PM
2.33
stock suspension
4000#
3.27 gears
27in tires
$hawn
09-22-2005, 05:28 PM
^^^4000# Bro, I'm not too far behind:lol:
Little Nicky
09-22-2005, 05:48 PM
2.0
stock suspention
2:73 gears
Slo_Si
09-22-2005, 06:36 PM
1.88 Eibach lowering springs, old setup 255-265whp....
DriftingDJ
09-22-2005, 07:38 PM
1.6 on M/T ET streets HICAS stock rear suspension, megan racing coilovers up front
Scott
09-22-2005, 08:56 PM
1.41 60ft's on M/T Slicks.
Rear:
Trick springs
Homemade drag shocks
Southside Lower Control Arms
UPR Double Adjustable Uppers
Rear Sub Floor and Torque Boxes Welded
Front:
Stock springs
Lakewood 90/10 Drag Shocks
Sway Bar Removed
All stock mounting points.
It did run 1.65's with all stock stuff, front sway bar removed, and slicks.
Suicidal Racing
09-22-2005, 10:43 PM
1.44
on 26x10x15 slicks with bmr torque arm,drag launch springs with air bag.
Tits McGee
09-22-2005, 11:43 PM
Bone stock.....2.2......should be more like 1.8....but I hate drag racing.
Strokd85
09-23-2005, 12:08 AM
1.29
wolfe anti-roll bar
single adjustable uppers
chasis engineering lowers
3 way adjustable rear shocks
front;
Lakewood 90/10s w/coilovers & 14" springs (don't remember the rate right now)
tubular k-member
tubular a-arms
TIM TIM TIM
09-23-2005, 12:14 AM
ha... 2.2 on baldys
Thats not too god for 4wd.
LSJ_Kid04
09-23-2005, 12:03 PM
2.1 w/ sprint springs , everything else is stock
2.2 eibach springs, kyb agx set on stiffest setting, Nitto NT-555's
Wheelhop ownz me:P
years ago(8-10 lol) did a 1.77 on worn out yokohama's. on all stock stuff even the swaybar still on..
i never really liked the track but i still think that was the most fun I've had there.
I've had it on slicks only time, did 1.5 something but that was just coming out soft and spraying early. more of hp 60ft time than a launch
oh and did a 2.0 on the bike the first night out. ahhahaha sad but it was hard and took me 4 or 5 runs to just get that...lol
1.91
stock susp , 2 year old 225/50/16 NT555R's
EliteZ
09-23-2005, 06:29 PM
1.47 J-bolts, 8.8in 10 bolt. MT 28W Slicks (78 Camaro) 2.037-LT1 Z28 Stock, Street Radials.
Tom N
09-23-2005, 08:54 PM
1.65
stock suspension.
Stock 205/55/16 tires.
primetime1267
09-23-2005, 09:26 PM
This past weekend @ BMP I pulled a,
1.46 launching at 5000 RPM on the spray
rear:
ET Drag 26" slick
Lakewood 50/50's
Lakewood UCA & LCA
Stock rear springs
front:
Lakewood 90/10's
Moroso drag springs
front sway bar-gone-
cant wait till track day.................
curtg21
09-25-2005, 04:56 PM
1.7 with slapper bars and drag radials
qitstrn
09-25-2005, 06:17 PM
1.6 Coilovers
uncle bens wildrice
09-26-2005, 04:29 AM
2.0 kyb's coilovers and bald bfg's
Slo_Si
09-26-2005, 04:34 AM
1.6 Coilovers
damn, not bad....1.6 is pretty damn good for fwd turbo...seen your new times...congrats...
qitstrn
09-26-2005, 10:40 AM
damn, not bad....1.6 is pretty damn good for fwd turbo...seen your new times...congrats...Here is the funny part. I pulled 1.6's on 22x8 slicks and now i'm on 26x10's and still cant pull under a 1.6. The best i have personally seen was allmotor hondas pulling 1.5's. This weekend a T/A pulled a 1.4 on mickey thompson Dr's at the track. :-o
BigBadBuick
09-26-2005, 01:28 PM
1.61 best, stock, stock, stock, 26x10 slicks :dunno:
04compgt
09-26-2005, 04:32 PM
1.55 with 26x10.5x15LT M/T ET STREET's , no front sway bar, stock shocks, stock rear suspension, 8.8 rear end, 28 spline moser axles, repacked posi...launching at 5000 rpms on spray :)
fadedSTi
09-26-2005, 06:50 PM
1.81 bone stock suspension
gje94z28
09-26-2005, 09:00 PM
1.55 with boxed trailing arms and ET streets.
myltwon
09-27-2005, 01:18 PM
2.19 stock suspension, street tires
RBTALLY
09-27-2005, 06:52 PM
1.65 with et streets on stock independent rear suspension
plan Z
09-27-2005, 08:36 PM
what car
Boostin97SE-R
09-28-2005, 07:00 AM
1.786 on stock suspension (independant) and 305/35/18 nitto 555r
fadedSTi
09-28-2005, 08:27 AM
i was on stock street tires also
rennteknik
09-28-2005, 09:04 PM
1.8's H&R's, Bilsteins....
vlevick
09-29-2005, 12:37 PM
Best 60' so far is 1.60 for my '01 Mustang GT convertible. I have Eibach lowering springs, Maximuum Motorsports caster/camber plates, Southside bars, frame connectors, 4.10 gears and 26 X 10 MT ET Drags. I also have removed the front sway bar. Last night was the first night I have had it out with the new engine and it ran a 7.21. The car was shifting "wierd" all night (automatic). I didn't figure it out until I was on my way home, I forgot to push the button to turn off the overdrive. Duh?!@#! I can't wait to take it out Friday night to see what it will run with it shifting like it is supposed to!
Steve B
09-29-2005, 11:50 PM
1.41 before front end coil over conversion and tubular mess. rear had ssm lowers and motorsport uppers on a M/T ET street drag radial. 1.39's here i come.
1.96 on 235 bfg dr's w/~12psi (1st time)
IRS
f&r sway bars (going to disconnect the rear next time)
spl subframe collars
j30 viscous lsd (3.90 gear)
DriftingDJ
09-30-2005, 12:28 PM
IRS
j30 diffs are different than the viscous lsd
nope its still an R200v part.
Silver35thGT
09-30-2005, 03:15 PM
1.35 on MT drag Radials,325/50/15 at 3400lbs..Double adj uppers,chromoly lowers,anti rollbar,stock rear springs with QA1 shocks,front is stock except for eibach drag springs and strang adj struts... That was this past Saturday at Bradenton...Anyone get a pic of the car????Its a red and silver 88gt with a chute...thanks Roger
Ender.
09-30-2005, 03:52 PM
1.81
Stock Suspension
All weather Kumhos
This was in the GVR4.
vBulletin® v3.6.4, Copyright ©2000-2008, Jelsoft Enterprises Ltd.
Content Relevant URLs by
vBSEO 3.2.0 RC5
