PDA
View Full Version : WTB Front Right Hub
BAMF
09-16-2005, 01:44 PM
So, the ABS sensor for my front right tire is bad. I've had ABS just turned off mullet style for a while, but I'm thinking it might be cool to fix it PROPERLY. Only problem is, corect me if I'm wrong but I believe I need to replace the entire goddamned hub to do so. Anyone have an ?ABS hub? that'll fit a 95 3.4l v6? OR am I stupid and can I just replace a sensor?
And yes, its dead, I've had it on a scanner and when the tire spins at < 7MPH, it reads 0 for some odd reason...makes stopping a bitch.
jim
10-05-2005, 03:17 AM
i have an extra hub on the parts car, but i don't know about the sensor, since i don't have a scanner. if your scanner is obd-i, i could use some help with the 94 3.4l engine.
BAMF
10-05-2005, 04:46 AM
It works with OBD-I or OBD-II...but I'm not the best at using it in either situation. It was inherited from a mechanic who actually knew how to use it, but we might be able to work out a deal with that.
jim
10-11-2005, 02:54 PM
sounds interesting. what's the brand and model of the scanner?
since nobody who knows a-b-s has responded so far, how confident are you that a replacement hub will solve your problem?
BAMF
10-12-2005, 04:38 PM
Traded the car, but thanks anyways :)
jim
10-14-2005, 03:06 PM
do you still have the scanner?
BAMF
10-21-2005, 04:32 PM
Yup, prolly gonna sell it.
