View Full Version : bitch's toy goes out a blazin
mrr23
09-15-2005, 09:50 PM
well, after getting a new best in her car, everything went downhill from there. next run, it tossed the main belt. so, IROCBeerBeer and i go to the parts store and get a new one. get one and have time for one more run. i toss the belt on that run as well. found it at about the 100ft mark. car missing pretty good. limped it to the shop. figured it broke a valve spring. well, i'm not so lucky on that one. pretty much figured out it's piston damage. haven't taken anything apart. here's pics of what's left of the #2 spark plug.
http://www.stealthram.com/familypics/formula/motordamage/sparkplug.jpg
http://www.stealthram.com/familypics/formula/motordamage/sparkplug1.jpg
Country Boy
09-15-2005, 10:00 PM
That sucks man. I experienced that a few times and finally I broke every ringland off #7. I do feel your pain.
mrr23
09-15-2005, 10:29 PM
#7 i could understand. but #2?
Country Boy
09-15-2005, 10:44 PM
wet or dry? Maybe check the injector.. How were the rest of them?
mrr23
09-16-2005, 09:19 PM
wet. pulled #4 and it's fine.
Country Boy
09-16-2005, 11:28 PM
Pull the injector and have it tested... #2 is strange to burn up.
mrr23
09-17-2005, 02:59 AM
the plug was dark from fuel stains just like #4. i used a boroscope to look into the cylinder. from what little i could see, i don't see any scarring of the wall. piston top looked okay. all i could see clearly was from 12:00 to 3:00 position of the wall and most of the piston.
mrr23
10-01-2005, 06:03 PM
well, i have the good, the bad, and the ugly of the motor. i took the passenger head off today.
the good - not the piston. not a scratch on it.
the bad - it took out the exhaust valve and part of the head.
the ugly - the following pics
http://www.stealthram.com/familypics/formula/headdamage/exhaustvalve.jpg
http://www.stealthram.com/familypics/formula/headdamage/exhaustvalve1.jpg
http://www.stealthram.com/familypics/formula/headdamage/pistontopclean.jpg
http://www.stealthram.com/familypics/formula/headdamage/pistonbottomclean.jpg
http://www.stealthram.com/familypics/formula/headdamage/pistonbottom1.jpg
http://www.stealthram.com/familypics/formula/headdamage/cylinderwall.jpg
http://www.stealthram.com/familypics/formula/headdamage/cylinderwall1.jpg
Country Boy
10-01-2005, 07:40 PM
Like I said in another thread. Visual isnt usually the best case. When I destroyed every ring land on my #7, my piston look great, the cylinder walls, looked great, but I pulled the piston out and got pieces. Fix the head and see what happens :)
mrr23
10-02-2005, 04:24 PM
in your case, did you have any head damage? i know, i'm trying to go the lazy route. new theory is it leaned out and burned the valve up. where it's missing the big chunk is right where the spark plug is pointed at. when i take the front cover off to put the cam in, i'll see if i can locate and piston pieces.
mrr23
10-06-2005, 09:09 PM
http://www.stealthram.com/camswap.htm
some pics of the install going on.
mrr23
10-10-2005, 10:20 PM
cam, adjustable timing chain, and lifters are in. head is almost finished. repair is done. taking valve seals to them tomorrow to reassemble the head and lap the valves in.
Pennywise
10-11-2005, 09:55 PM
man that does suck bout the valve, but it happens, good luck on the repair man
mrr23
10-11-2005, 11:02 PM
bottom and front are done. heads, headers, and intake is left.
Country Boy
10-11-2005, 11:15 PM
Sweet man! I would do a leakdown on the one cylinder to double check.
mrr23
10-11-2005, 11:19 PM
be nice if i had one. what i did do was pour a cleaner (kinda like lighter fluid) into #2 and #4. had both pistons at he same height. that way the same amount was in them. after 10 minutes, neither had leaked down. an hour, both had lost the same level. now, that won't account for ringlands broke under the 2nd ring. but, what would be the chances of that? nothing in the pan. and i looked through the cam hole. didn't really see anything obvious through there either. but, knowing my liuck, it's broke. we'll see in the next couple of days.
Country Boy
10-11-2005, 11:23 PM
The liquid really wont do much because the rings will still seal it, also, while running, your dealing with compressed air. Not trying to be an ass or anything, just an FYI :)
Good luck with it bro and let us know how she does. Hope the ol' lady didnt kick your ass too bad ;)
mrr23
10-11-2005, 11:26 PM
i know. but, it would've told me if the top ring itself was broken. the other thing i could've done was make a plate to bolt over the cylinder with a hose end on it. that way i could've put compressed air to the cylinder. but, didn't have any metal lying around. i'll most likely put compressed air to the cylinder once the head is on. that way i'll know before i start it.
mrr23
10-15-2005, 05:59 PM
finished car thursday. cam has just enough sound to know it isn't stock. been tuning since friday. getting better. cold start up is about perfect. gotta work on in gear idle.
SteveIGuess
10-20-2005, 10:10 AM
I experienced the same problem with n20, but with ummm different results...
http://img.photobucket.com/albums/v625/steveiguess/pistonsmall.jpg
gave me an excuse to build this though.
http://img.photobucket.com/albums/v625/steveiguess/m2.jpg
383 stroker, eagle forged comp 11.1 assembly, ported dart pro 1 heads, edelbrock air gap intake, custom hyd roller cam, 1.6 roller rockers, etc...:lol:
mrr23
10-21-2005, 09:39 PM
pics of the ordeal
mrr23
10-30-2005, 08:23 PM
track last night. new best on motor. slower on n2o. lost the pass front o2. have some dyno results. but, i think i have a bad injector to boot. best i could get was 14:1 AF. so, these are preliminary results until i can get all this situated.
seeing as it was cooler than sept 19th, i'll use the best run i had back in 27 jan 2005
there was some differences bolt on wise
borla 3" adjustable catback
no cats
12.822@108.59 1.930 60ft (http://www.stealthram.com/familypics/formula/timeslips/1282nocat.jpg)
this time around
bassani tru-duals
bassani metallicats
vinci 062 cam
.010 cut off heads
12.678 @ 110.36 1.995 60ft
so, .2 and 2 mph more so far. might get it back out next friday if i can get the tuning better.
mrr23
10-30-2005, 08:24 PM
here's the 12.67 NA run (http://www.centralfloridastreetcars.com/videos/1267run.wmv)
littlefranks ss
10-30-2005, 10:53 PM
if you need some parts . we have ls1 motor parts all over the shop.gm dealer.
mrr23
10-30-2005, 10:55 PM
thanks for the offer. i'm looking for some stock 98, 01-02 injectors. they are the 28.6# injectors. thinking of upgrading seeing as i might have a bad one. plus it won't hurt.
littlefranks ss
10-30-2005, 11:02 PM
ill check tomorrow ,if power is on ,been out of work for week ,was there but no power to work.
littlefranks ss
10-30-2005, 11:03 PM
what about zo6 injectors.
mrr23
10-30-2005, 11:04 PM
i think those are 28.6# also. would still work. thanks for checking.
mrr23
11-01-2005, 11:44 PM
rev in park (http://www.centralfloridastreetcars.com/videos/revinpark.wmv)
idle in park (http://www.centralfloridastreetcars.com/videos/idleinpark.wmv)
idle in drive (http://www.centralfloridastreetcars.com/videos/idleindrive.wmv)
vBulletin® v3.6.10, Copyright ©2000-2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by
vBSEO 3.2.0 RC5
