View Full Version : some pics of my project, 56k...probably not
Josiah
08-28-2005, 08:47 PM
well, heres a few pictures of some progress of my SRT engine swap into my 98
GsEclipse02
08-28-2005, 09:45 PM
i know u said srt4 but is that a srt4 motor ..... or a dodge stratus motor?
Fast420A
08-28-2005, 11:22 PM
That's an SRT-4 motor. Or at least intake mani, valve cover, timing belt cover, throttle body...
Looks good Josiah. What turbo is it?
neondriver
08-28-2005, 11:33 PM
sweet, bet that manifold was alot easier than mine
Josiah
08-29-2005, 10:10 AM
its an SRT4 motor....stock internally, with my hahn 20g, the TB is actually my modified stock 49mm TB from my 98 since it bolted up and I didnt feel like buying an SRT4 one just yet, as you notice with my wiring, this is being run from a standalone(hence no MAP sensor in the manifold, I tapped it for a GM MAT sensor instead) and some of you may be interested to know that the fuel rail is from a 96 SOHC car, bolts right up with some nuts used as spacers
LS1Fever
08-29-2005, 12:09 PM
damn Josiah, havent heard from you in awhile. your making alot of progress. hit me up man. id like to see it.
Josiah
08-29-2005, 12:51 PM
yeah, my built '96 2.4 decided to spin a rod bearing(bad judgement when originally assembling it, I decided I didnt need a new crank because of a small scratch on one of the rod journals...I was wrong....anyway, this motor is to replace the 96 while I tear it down and rebuild it, then I will probably end up swapping the '96 2.4 engine into my '95 neon, but once I get this thing fired up and driveable I'll be by to see you with it(currently need to get my trigger wheel mounted on the pulley and some I/C stuff finished, then I should be set to go
Fast420A
08-29-2005, 02:14 PM
Does the 96 SOHC rail have a schrader valve on it and how does the size compare to the SRT stock rail?
Josiah
08-29-2005, 02:34 PM
yes, the SOHC has a schrader valve on it(my FPR is connected to it via the SS line in the picture) as far as size vs the SRT rail...no clue, large enough to support 500HP though so I dont much care, since this block will never see more than that anyway
neondriver
08-29-2005, 03:51 PM
there isnt much of a difference in size at all. when i bought all my turbo stuff it came with a srt fuel rail and stage 1 injectors. i compared the fuel rails and there pretty much the same size, it wasnt worth the hastle of putting a valve on the srt one so i just kept my stock one that already has a schrader valve onit.
Fast420A
08-29-2005, 06:15 PM
I'm a :tard: I should just look at the pics next time.
grindpunk16
08-31-2005, 02:32 PM
lookin good bro cant wait to see it when its done oh wait thats right im in pa :(
see ya during christmas
Content Relevant URLs by
vBSEO 3.2.0 RC5
