View Full Version : st185 3sgte swap
Xiwei
08-22-2005, 03:06 PM
i have a st185 automatic 4afe celica currently in my possession. jarco is shipping me a st185 alltrac clip for the swap. but i have a few questions.
1. what sort of wiring mess am i expecting?
2. how about harness extension? any of that? would the jdm gauge cluster working in the usdm car?
3. will the clutch pedal assembly from the jdm car work in the usdm vehicle?
4. transmission wise, i know i need a 5sfe tranny, what sort of power am i expecting that to hold?
even if you guys odn't know, a point to the right direction is much appreciated. thanks!
kbprice
08-22-2005, 05:35 PM
You may be better off getting an MR2 tranny, it will hold up better and you can get one with an LSD unit. They are more pricy but will hold. I don't think the JDM clutch assembly will work, someone correct me if I'm wrong. If your going from auto to 5 speed you're going to need all the clutch components anyway, master cylinder, slave cylinder, shift linkage, shifter, pedels, etc.
You may be able to call XAT and find out for sure I know they are doing a bunch of 3sgte swaps.
toyotajoe1980
08-22-2005, 05:40 PM
what Celica do you have because the st185 never came with an (a) motor
the st162, which was the body style from '86-'89, came with an 3sge(GT-S) and a 3sfe(GT & ST)
the st165 (same years) came with an 3sgte(all-trac, GT-4, or GT-All wheel drive depending on the country where you purchased it)
the st182 early 90's and also came with another (s) motor the 5sfe
the st185 on the other hand came only with a 3sgte all-wheel drive
there was an (a) motor in some 5th gens but the cassis code was (at)...somthing
to understand why in any chassis code the first designation is the motor 4a=a 3s=s 2jz=jz
the second designation is the vehicle e=Corolla t=Celica a=Supra
and lastly the numbers at the end are to designed to let you know other key parts about the chassis the higher the no. the more structurally sound the chassis
but any way the answer to you question is if you are going to swap an (s) motor in to an (a) car you will need little more than what comes in a complete front clip.
the main thing you will need is the 2wd tranny either the one from a Celica GT-S or a Celica GT
and then to finish your combo throw in a mega-squirt in place of the computer
if 3sverizon ever gets back on he can tell you everything you need to know about the swap his name is Ryan
Mike431635
08-22-2005, 05:48 PM
Make sure to go to Celicatech.com, register there, and post this in the Forced Induction forum. Everyone will be very interested in seeing this done, as nobody has (to our knowledge) completed a 3SGTE swap in a 5th gen ST.
There is a FAQ by Dr Tweak on the Celicatech board that talks about how to wire up your car for an engine swap, it's a MUST for anyone doing it themselves. If you can read wiring diagrams, you shouldn't have *too* much trouble.
You can either extend the harness to go into the passenger side of the USDM car or you can just put another hole in your firewall and do it the same way it is on the clip. People have been successful both ways. Extending can be a little tedious but I believe ChrisD on the Celicatech boards does any swap wiring including wire extending for pretty cheap.
No, sorry. Go to a junkyard and grab all the parts you need for the transmission swap from a GT or GTS. 4th/6th gen parts may work but don't take my word for it. Check out toyotacelicaonline.com and go to the Modifications section, then look for Hooligan's Auto-to-Manual swap FAQ. It's pretty detailed, but you will also need extra parts for yours since it is an ST, and those vary depending on which tranny you go with.
Don't expect it to hold very long if you drive it hard or up the power. A lot of people have used the 5SFE's S53 trans (and the S54 from the 6th gen Celica), but the majority conclusion has been that it's more worth it to swap in an MR2 trans (E153). If you look hard enough you can find a LSD one for $400-500. That's really the way to go. You need the GT-Four crossmember to use this trans (comes with the clip), and of course you will need to do some mount work whether you go with the S53 or E153. Oh, and don't forget-- the V6 Camry and Solara transmissions (already FWD, no conversion necessary) are also E153's and can be used. No LSD on those though. You can find more info about all this on Celicatech.
I hope that's answered some questions. You might also want to talk to Ryan at XAT Racing about this swap, he should be able to offer some advice.
Mike431635
08-22-2005, 05:50 PM
Oops, he posted while I was typing that. You can also find information on chassis codes at Toyotacelicaonline. The one inaccurate thing mentioned about is structural integrity-- the numbers don't necessarily mean that. For example, an ST184 (5th gen GTS) is actually less structurally stable stock than an AT180 (5th gen ST). The reason-- the ST is a coupe and the GTS is a liftback. Less rigidity. You see my point.
toyotajoe1980
08-22-2005, 05:55 PM
Sorry mike431635,
I was miss informed,
thank you.
Orion ZyGarian
08-22-2005, 08:33 PM
When did you get this and where is it? Is it for a customer?
3SVERIZON
08-23-2005, 01:23 AM
if 3sverizon ever gets back on he can tell you everything you need to know about the swap his name is Ryan accually my name is Sean and all you have to do is give me a call at my shop 727 572 4340 and i can answer any of your st18x or 3sgte questions
Xiwei
08-23-2005, 12:02 PM
it's a at184, 91 model, 4afe 1.6 liter. and yes, it's joel's car. the car looks like mike431635
and we are getting a whole st185 front clip, so i figure we would have all the parts to swap to 5spd
Mike431635
08-23-2005, 06:55 PM
Just fyi, it's an AT180. Don't want you to feel dumb or anything, but it's on the firewall on the passenger side, top of the engine bay :)
toyotajoe1980
08-23-2005, 07:29 PM
sorry got you confused with some one else didn't you work at xat awhile back
ElSuperSpic
08-24-2005, 12:30 AM
Hmm only advice that i could really give is go to sean for your st to be swapped and definately register for celicatech.com Very helpful on there. I myself have one swapped celica GTS and I'm about to swap my other GT lift back. I wish these cars came with this engine already. Well worth the swap!
Mike431635
08-24-2005, 02:41 AM
Wait until I get my GSX Nelson, 4G63 > 3SGTE and AWD > FWD. Sorry ;)
ElSuperSpic
08-28-2005, 12:22 PM
What ever buddy, Don't get full of it mikey. LOL I easily walked my friends 99 gst at 16psi from a roll. I was only hitting 10 that night. So i can only imagine a GSX sure its awd but its heavier. From the hole you might have me, but once I wind out your dead. :-P
lofer
08-28-2005, 02:03 PM
I have two e-153s for sale. The one is non-lsd and newly rebuilt with steel shift forks and new everything ect.ectThe other one is still in the shop being rebuilt . They are both 91s.Btw I live in Ocala so delivery is no problem
kbprice
08-29-2005, 10:27 PM
So is the other an LSD unit? What are you looking to get for it? PM me.
williamb82
09-05-2005, 10:02 PM
if youd rather have an air/water i/c for your swap instead of the stock st185 air/air top mount, lmk. i have an st165 air/water i/c for sale.
twistedimage92
02-21-2006, 10:38 PM
i didnt read the posts but i am over on the east coast... give me a shout if u need any help... we did my swap in 25 hours... admin@tiecc.net
twistedimage92
02-21-2006, 10:42 PM
my car is also an stx... which is the same as the st
vBulletin® v3.6.10, Copyright ©2000-2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by
vBSEO 3.2.0 RC5
