View Full Version : Daytona Losing Volts
ToyotaMRK88
08-21-2005, 12:01 AM
After changing the alternator and the battery my car still wont hold the charge. some said it was the voltage regulator but i looked and it doesnt look like that car has one. than someone told me its the Power Control Module. What do i need to do?
Dano Moparo
08-21-2005, 01:24 AM
yes the voltage regulator is part of control module. You need to replace the module, no parts are serviced for it.
ToyotaMRK88
08-21-2005, 01:51 PM
where is the computer and is it hard to replace?
ToyotaMRK88
08-21-2005, 10:14 PM
what kind of exaust should i get? straight pipes, flowmaster, or ricer exhaust
HMCK20
08-21-2005, 10:54 PM
your daytona is turbo right? 3" straight back or dump out the side if you can.if its NA then get a greddy or or something if they make a kit for that car.
Dano Moparo
08-22-2005, 09:30 AM
The computer on that is called a "power module" its located in the right front behind the battery. Its a fairly large black plastic item with large holes at either end for the fresh air to run thru it.
What kind of V do you have with the car '0N' and running?
ToyotaMRK88
08-22-2005, 09:50 PM
with a fully charged battery it will be at 12 or 13 volts. after it runs for about 10 minutes it will drop to 8 volts
I find that strange that just idling or running will drain your battery so fast. Is the battery 'good'?
I assume the car dies if you disconnect the battery after starting it?
You'll want to verify the wires going to the alternator are good. Esp the ground.
Usually there is a wire to the PCM that controls the magnetic field on the alternator ( this determines how much "V" the alternator will oputput). Check that too.
This is all under the assmption that:
I'm no expect on that year's PCM but I'll trust the post.
ToyotaMRK88
08-24-2005, 02:19 PM
I need some more advice on what kind of exhaust to get. what kind of intercooler will fit on there. whats the biggest i could get the rims without it messing it up.
ToyotaMRK88
08-24-2005, 02:27 PM
also what wires go with what switch for the power windows. and what would it take for me to make them manual windows instead of power windows
Grease
08-25-2005, 03:46 PM
Go check out this site..
www.turbododge.com
Lot of good help there..
Dano Moparo
08-29-2005, 04:26 PM
all you really need to change is the regulator, that and you'll need a handle too. Prob best and go the bone yard and grab it since its long discountinued from Chrysler. Looks like they used manual as an option from 84-89 and are the same. The power set up is the same to 1993 . I can't download any wiring diagrams back that far from Chrysler so you prob should just get a service manual for the wiring.
vBulletin® v3.6.4, Copyright ©2000-2008, Jelsoft Enterprises Ltd.
Content Relevant URLs by
vBSEO 3.2.0 RC5
