PDA
View Full Version : Just Ordered....
HMCK20
08-19-2005, 12:08 AM
My AGP WGA and Turbo XS MBC, and then my JMB catch can!!!!!!!!!!!!!!!! not very important but im excited!!!
GsEclipse02
08-19-2005, 12:16 AM
since you have a WGA is there a point to have a boost controller?
HMCK20
08-19-2005, 12:26 AM
absolutely gotta control boost some how!
DirtyShroomz
08-19-2005, 12:31 AM
just turn the wga... that controls the boost, specially a MBC, if it was a EBC i could understand but a MBC on a WGA is.... pointless, i guess its just easier to get to???
GsEclipse02
08-19-2005, 12:37 AM
im going to have to some what agree with you .... 1st time ...
HMCK20
08-19-2005, 12:48 AM
i know this but whats easier adjusting preload with no real general idea of how much movement equals how much increase or decrease. or turning a allen screw that one whole turn is about one psi?
Fast420A
08-19-2005, 01:58 AM
You are going to have to set the boost you want by adjusting the WGA and then you use the MBC to get more boost than the amount you set the WGA to. It seems a lot of the Ohio guys are dynoing more HP with JUST the WGA set to the boost they want with no MBC. That's my plan at this point instead of the stage 2 WGA and a MBC like I have now. The only reason I would use a boost controller is if it was an EBC that you can change on the fly.
Off-Topic
08-19-2005, 02:01 AM
yea just use wga i had a mbc it sucked now i run just off wga an i can feel the difference
bluelighting
08-19-2005, 09:30 AM
with a wga and no boost controller, you boost goes up every gear correct? I had just a wga on my car, and 1st would be like 16, 2nd was 18, 3rd 19, and then 4th and 5th I would blow out the spark. None of you guys have that problem now? I have a wga dn mbc and I spike 19 and drop to about 16 every gear, and my car dynod pretty damn well for what I had.
CobraSpdRH
08-19-2005, 09:50 AM
My car sees a higher spike with the MBC than it did with just the stage 2 WGA, but all in all that doesn't relly help much. It seems like AGP WGA by itself or with an EBC are the way to go, just beware the part throttle overboost!
Fast420A
08-19-2005, 02:12 PM
I set mine for a 4th gear 19psi spike so I see around 14 in 1st, 16 - 17 in 2nd and 3rd. The stage 2 WGA is a pain in the butt, running the AGP WGA off of the green line should give you the best results. The boost controller does give you more of a spike and then lets it drop down so I really think the AGP WGA alone is going to give the best results inless you want to run an in car EBC.
bluelighting
08-19-2005, 02:19 PM
If I let my wga dictate what boost I had, I'd have lower in the first two gears, then too much in the top two. Where I have my wga set at now, I think that it would spike above 20 in every gear, and would holt about 16. The boost controller keeps the boost at 19 instead of letting it get out of hand and spike to like 24 or something, then it drops to 16. With the wga alone, you might get it to hold 13 or 14, but you'll be pushing the envelope on whether you'll blow spark, expecially without S1. I could be wrong...if you try it and it works, let me know, I might go that way instead.
ACR2NV
08-19-2005, 06:45 PM
let me know when you get the setup....it can be made to work ;)
GsEclipse02
08-19-2005, 07:10 PM
if you get to drive his car :lol:
Skittle
08-19-2005, 08:12 PM
Wow,the most i see is 11-12psi in first all the way to redline,anymore boost and going from a dig would be utterly pointless to me,traction is still shitty,spinning till 60=teh win. :lol:
Fast420A
08-19-2005, 10:49 PM
Of course it can be made to work, but most people that run just the AGP seem to make more HP and have less issues.
HMCK20
08-20-2005, 02:04 AM
yea i heard that boost increases with every gear. no matter what works better or whatever im gonna use some kind of boost contolling device no 19 psi for me plus the 16g maxium effiency is only 20 psi so..... parts will be here shortly!!! and jason be sure to call me before you get to workin on your paint! 727-420-8474
bluelighting
08-20-2005, 10:04 AM
you know I will Thanks. Let me know when you get the shit it. I have the JMB cc on my car, and it'a motherfucker to put on if you dont take the mm out. I have all the toold to do it, and the rest of the stuff if you want help.
HMCK20
08-20-2005, 05:09 PM
well yours is the one thats on the passenger side. the one made for a stock airbox right? i bought the one that mounts to the battery tray. the one made for a aftermarket intake. but i will def keep that in mind when it gets here!
bluelighting
08-20-2005, 05:26 PM
Yea, mine is the one for the stock airbox. You should get some prothane mm inserts while your at it. they are like 20$ and THey help a hell of alot. you're goign to love your car when you get done with it. BTW, which intake did you get?
Jayson
ReDKeNSRT4
08-20-2005, 11:17 PM
buy tires.... 225/45/17.... let me know if ya need some...:-D :naughty:
Off-Topic
08-21-2005, 12:03 AM
^^slow
ReDKeNSRT4
08-21-2005, 12:29 PM
^^^^^^^^ hater
HMCK20
08-21-2005, 03:56 PM
Jayson
injen sri, do the inserts really help with wheel hop? i have heard several stories so lmk what you guys think.
bluelighting
08-21-2005, 06:36 PM
They help, no doubt about that. THey aren't too bad putting them in, but they are a litte bit of a bitch.
ReDKeNSRT4
08-21-2005, 08:25 PM
motor mounts are real easy... cheap mods... get a 160 stat too
HMCK20
08-21-2005, 11:52 PM
yea i wanna get the stat cold enigine stops at 150 right?
bluelighting
08-22-2005, 01:08 AM
closed loop is at 150 I believe. I have the 180 in mine, and it works fine. Ken's runs great as well with the 160 in it. Personal preference on the t-stat. and if you get the prothane mm inserts, get the red ones.
HMCK20
08-22-2005, 11:17 PM
im not sure what to do i think im gonna go with 180 cause i dont wanna be go in and out of the closed loop.
bluelighting
08-23-2005, 12:23 AM
That's what I have. It actually runs a litle bit cooler than 180. Make sure that if you do it by yourself, tht you put a bucket ot something under your car where the t-stat is. It leaks everywhere.
Fast420A
08-23-2005, 12:59 AM
I have the 180 Tstat also and am completely happy with this one. It's easier to find at Pepboys/Napa than the 160 is which made the choice easy.
HMCK20
08-26-2005, 11:55 PM
thanks i have been everywhere autozone and discount and no one has it. but ill give a shout to pep and napa thanks. also was it listed under srt4 or a 2.0l neon?
Fast420A
08-27-2005, 09:46 AM
Nope, it's not listed this way.
http://www.srtforums.com/forums/showthread.php?t=165152&highlight=thermostat+180+stant
You can find the stant brand at Pepboys.
Stant part #29788
cali
08-27-2005, 02:33 PM
I say stay away from the 160'S. Maybe use the 180, even those I dont recommend any more. After having both, and doing serious logging back in the day.
1.They make the temp more unstable. Especially in stop n go or low speed driving.
2.Cause more gas consumption
3. Some times the PCM never sees operating temperatures with the 160.
I have found that a fresh mix of coolant,mixed correctly with distilled water and redline water wetter does a perfect job with the stock thermo, without causing unstable temps, or screwing with the gas consumption. Some say redline can cause some glycol build up or something, but I believe in the flush once a year policy, so I'll take that chance.
Earlier this year I swtiched back to a stock thermo, with the proper mix. I probably went over the midline once since then.
HMCK20
08-27-2005, 05:56 PM
thanks very much guys im gonna try to hunt down this stat. but i wll also watch how consistent my temp stays. thanks again!!!
HMCK20
08-27-2005, 08:27 PM
got two fo them thanks for the info.
