View Full Version : i have no clue what i'm doing - amp help
steve
08-09-2005, 08:24 PM
ok so i want to get an amp for my sub i don't have a clue on what to look for
spec's on sub
10 inch component subwoofer
400 Watt Maximum Power
IMPP Composite Cone
4-Layer Copper Voice Coil
Vented Pole Yoke
Frequency Response: 20-4500Hz
Sensitivity: 90dB
Sealed/Ported/Bandpass Enclosure
Recommended Enclosure: 1.0cu ft
Speaker Type Subwoofer
Coaxial No
System Type 1-way
http://www.dealtree.net/cart/select_item.cfm?cont=14281&view.htm
found that online
now i just need a cheep amp nothing to brag about
thanks
Notladstyle
08-10-2005, 02:03 AM
that sub looks like it was made of aluminum foil :p How about a nice Alpine Type-S sws-1242 for $90 ? I think you will be much more happy with that.
oh and I have a brand new amp you can get off me cheap too.
Epidemic813
08-11-2005, 04:19 AM
for the sub you're looking at you would want an amp that will pump 200W RMS 400W Max if you're only planing on running one. 400W RMS/800W Max if you're getting two. dont have to supply full power tho you can go lower prolly 150W RMS per sub, and still sound pretty hard/clean. but you need to find out how many ohms that sub runs at to match it with the amp. and if its single or dual voice coil. when you have that go to http://www.cardomain.com/shop/subwoofers and scroll down on the right you will see subwoofer wiring guide, you'll get a pop up that asks for number of subs and impedance. that will tell you if you should run mono or multi-channel amp and what ohm amp to get.
but yea i can get you some Audiobahn Dub100s for less then that and specs are a lil nicer. 400watt max would mean you're only getting 200W rms. still a 10"
300watt RMS/ 600w max
18hz-500hz
93.9 db
dual 4ohm voice coil
2ohm and 8ohm operational
$60 each
$110 for the pair
I have two that are BRAND NEW, still in box, with 1 year warranty just sitting around. have a car audio business, the person i ordered these for never paid so im getting rid of them.
and if your not afraid to try something new and want a complete system that pounds CHEAP. check out http://dieselaudio.com/.
two NSX12 12" woofers and one NSH800 2 channel amp AMP, 5 year full exchange warranty for $250
steve
08-13-2005, 01:33 PM
thanks for the help but i don't need any sub's
got theses things two years ago
only going to be running one not looking to win shows or anything like that just need some bump in the trunk lol
TIM TIM TIM
08-13-2005, 03:06 PM
18hz-500hz
93.9 db
$60 each
$110 for the pair
rms of a sub is not always half the max...type r's are 1000 max but only 300 rms. and there are TONS of others like that
Epidemic813
08-13-2005, 05:52 PM
thanks for clearing that up, but i was only giving an aproximate since i didnt find exact number, 10"s shouldnt be any lower them 200w rms lowest ive seen was older subs i think about 150W.
Notladstyle
08-13-2005, 06:56 PM
there is no set standard for rated power handling, the lower the RMS rating, generally the higher the s/n ratio - hence better(not louder) sound Higher RMS rating simply allow for further excursion of the voice coil, that rating alone means nothing to anything.
the 01 series mtx 4500 12" subwoofers were like 45w rms and still hit clean, your RMS rating is honestly a dream, no one actually runs at RMS most of hte time, if they did not only would their cars cease to run within weeks, but they wouldnt be able to hear.
vBulletin® v3.6.4, Copyright ©2000-2008, Jelsoft Enterprises Ltd.
Content Relevant URLs by
vBSEO 3.2.0 RC5
