Auto-X/Road Racing Autocrossing, Road Racing & Other Forms of Sanctioned Racing
Koni Yellow's+ Springs or Coilovers?
Old Jul 31, 2005 | 10:34 PM
BeQuietAndDrive's Avatar
the whistles go whooo!!!1
Default Koni Yellow's+ Springs or Coilovers?
Well, the time will come soon when I will purchase some suspension goodies.
Koni Yellow's (sports) have just been released for the xA. I have heard many good things about these. I could buy these, and then pair them up with some good springs.
There is also the option of coilovers, which would be a good bit more expensive. I don't think I really "need" the adjustable ride height feature.
Or, I could go with Ground Control coilovers, and match them with Koni Yellow's. I have heard good and bad about Ground Control.
Any suggestions?
EDIT- I just found a really great deal, it seems. 4 Koni Yellow's and 4 Eibach Sportline's for 649.99. Anyone have experience with these brands?
Old Aug 1, 2005 | 04:57 AM
Leonard's Avatar
OUCH!!!
Koni makes great shocks. I've got their 3012 aluminum body double adjustable shocks in the FFR and they're amazing.
Eibach springs are fine.
As far as coilovers go, you gain ride height adjustability. That's why ricers love them and think it's great for performance. I consider it (to a large degree) to be a red herring. The down side to that is that by changing the ride height, the car operates in a different part of it's wheel travel and you can easily get into areas where you have unfavorable camber changes and things like that. Cars are designed to have good suspension behavior at the oem ride height.
The UPSIDE, if you're willing to spend the money on the alignment is that you can have the car corner weighted. Small (VERY small) changes in ride height can shift the weight around signifigantly between the wheels. The idea is that you shift the weight around so that the cross weights (LF+RR) and (RF+LR) are the same. Typically it's done with ballast in the driver seat that is roughly equivilent to the driver. I'll spare you the math involved, but the end result is a car that is very well balanced.
Something to consider before making any changes is how it will affect what class you run in. Right now, I know you only run with sunriders. Their class system is very simple. If you start running with other groups, you need to be aware that springs or coilovers could bump you to signifigantly more competative classes.
Old Aug 1, 2005 | 08:52 AM
Yeah, thankfully Sunrider's only classes on experience, which can be good or bad.
In all honesty, however, since the xA is my first car I have autocross experience in, I'm not sure how "competitive" it is in it's class. Most likely this will be the car I use to get experience in, not to be competitive in. So me being bumped into a different class is not a big issue to me.
Old Aug 1, 2005 | 10:04 AM
Loren's Avatar
The benefit to a coilover setup on most cars is that the aftermarket spring kits usually lower TOO far. Looks cool, but you run out of suspension travel and sometimes unpredictable handling at the limit.
Old Aug 1, 2005 | 11:24 AM
99TL's Avatar
The Hoff
I just got the ground controls with konis... so far I love them.. .It is a little rough for everyday driving but the car felt great autocrossing and during regular spirited driving. My car has been corner-balanced.
1995 BMW 540/6 - The Track Rat
2009 Ford Escape - Stock Toy Hauler/DD
2007 Lexus RX350 - Stock Wife Hauler
2009 Kosmic - The Toy - 125cc Vortex Super Rok TAG, (For Sale - $2800)
2007 Intrepid Silverstone - The Faster Toy - CR125 6-Speed
Old Aug 1, 2005 | 11:25 AM
kickslop's Avatar
noodles
- Decent coilover setups can be had for $1400-$1500 nowadays, which includes pillowball tops that would be an extra cost in a Koni + springs purchase.
- Those pillowball tops very often offer adjustability for a more aggressive alignment than a stock setup usually allows.
- Pillowball tops may irritate the hell out of you. They clunk. If not today, or in the first 6 months, they will eventually. You are also increasing noise and vibration transmitted into the cabin through the chassis. Just something to consider if this is a daily driver.
- Most coilover spring rates are high. You can sometimes get them with lower spring rates, but there is often a wait, and you'd ideally want the coilovers revalved for the lowered spring rate. Some coilover manufacturers offer "US spec" products that are geared toward aggressive use with streetability in mind (revalved + non-race spring rates). Just another thing to consider if this is your daily driver.
- And yes, if you SLAM your ride and totally botch your suspension geometry's original design, your car will handle like ass. For any reasonable person, like yourself, this is not a concern.
Old Aug 1, 2005 | 09:54 PM
I would like ground control's, but was told that often they don't work well for daily driven setup's. quite a few scion owners who have them have told of the rear springs popping out after raising the car too much, and I'd be quite worried of them popping out going over a speed bump or something of that nature.
Old Aug 2, 2005 | 05:00 AM
Loren's Avatar
There are ways around that if you're willing to spend a few more bucks. They're called "tender springs". They fully compress and do nothing under normal circumstances, but when you get enough droop to slacken the main spring, they "tend" to it and keep everything in place.
I'm wondering what the heck folks are doing on the street to get that much droop!
Old Aug 2, 2005 | 09:06 AM
Who knows. One owner with an Echo stated that he was driving on the freeway going 75 when one of the rear springs came loose and popped out. He must have hit one hell of a bump.
Old Aug 2, 2005 | 09:16 AM
Loren's Avatar
That sounds like BS to me. The only thing I can see happening (and it almost happened to me once) is if the circlip that is used to support the lower spring perch on the Koni shock is not properly installed, it can shift and possibly allow the spring to push the perch down.
I caught one of mine during a pre-track inspection a few months ago. I hadn't fully seated the circlip in it's retaining groove and it was half way out of the groove in the shock. The spring perch (GC threaded barrel in this case) had cocked down on that side. Everything was still together, but the top of the threaded barrel was rubbing against the inside of the spring. A few good hard bumps could have dislodged that circlip, or possibly vibration could have caused it to break... that corner of my car would have taken a nose-dive at that point.
But, other than that issue, I don't see how the springs themselves are going to "pop out" of the upper or lower spring perches unless you get the car completely airborne. Generally speaking, if you do that with a street car, you'll have other things to worry about besides your springs being seated.
