Anyone Know of a AWD part out 2g????!
I need a right side assembly.
I am pretty sure just the upper control arm I think.
I cant remember. But pretty much I need the upper control arm and perhaps the hub.
When getting my clutch done one of the bolts on the control arm was stripped at one point, and then the shop used JB weld to fix it!!
Whatever shop
Well we used another bolt since it compressed and held tight but I figure time to swap it out.
But at the same time the wheel bearings (Im pretty sure) are going out!
When you throttle. No noise. When you let off the gas there is a squeaaaaling and when you take out of gear the noise dissapears or if you throttle it goes away too.
Anyone know where I can gank these parts?
Whatever shop
04GSXR
96 Eagle Talon TSI AWD.
04GSXR
I was at Cophers (sp?) around 6 months ago and I came accross a 2g gsx. Its on import side right on the outside. Motor/tranny was gone but the hubs were still there, but this was 6 months ago.
try www.car-parts.com
its a database of junkyard parts, works for me very well when I need a part
somehow the gear on the outside came off track and then ate a hole thru the tranny cover on the side.
tranny rebuild, or that gear replacement and pin replacement and tranny cover.
i have the hole front suspension to an gsx 2g call me at 4010123
It turned out that the tranny is "dead"
No clue until I find out how much a new tranny would cost or how much to rebuild. so currently trying to find one.
04GSXR
04GSXR
