View Full Version : Alighnments!!!
hachibill
07-30-2005, 12:29 AM
well since we're coming up on a dday i'd figure i'd post this up. all you 240/ae86/any drift car owners. if you need any kind of suspension work/tuning done let me know. i also have access to a computerized alighnment rack where i work and can cater to high performance type alignments and or extremly lowered veihicles. i have done plenty and can set your car up how ever you desire as long as you have proper adjustments available. but you have to drive your asses down to sarasota so i can do it. prices vary per type of car and how much adjusting i have to do , but i'm cheaper than everyone else. i however can not corner weight due to no scales. but i can fix shit after you install it so it all works together how it should. i can even install your suspension then do the alighment right there so as to not tear up your tires.
DOOOOOOOOO IT. I had my car aligned there. Did awsome work didnt even scrape when I put it on the rack (ask bill my car is on its nuts),. This was after I got my tein tie rods put in and my toe was all fucked up! But now its like 10000x better. So anyways yeah alignment is key for reliable feeling when drifting!
SilentKrnSoulJah
07-30-2005, 12:43 AM
bill ill let you know when i get my shocks and let u install and alighment o yea and i wanna cut the springs too so i can make my car just like ur ae86 :grin:
Forgot to add also. He will set it to the best specs we (as hot tea) have found for our cars! no need to go to some samp who doesn't know what the eff they are doing and giving you Daily driving BS, telling you how 4 degrees of negitive camber will kill your tires.
He can do better work with all the adjustable arms, but he will get the best specs he can with the stock arms and bolts.
Jonas
07-30-2005, 01:06 AM
so if i had fully adjustable rear supension already on how much to get those adjusted to get a car a good driveable sensation?
hachibill
07-30-2005, 01:21 AM
one more thing, if your car is a s13 it makes my job alot easier if the exhaust is off the car so i can get to the rear drivers adjustments.
RussianKid
07-30-2005, 01:37 AM
how much to adjust the front on my 13?
mranlet
07-30-2005, 02:02 AM
normal rate +$30 that you owe me.
Do you work on Subarus? ;)
aphxero
07-30-2005, 12:21 PM
okay how about doing my ae86?
I'll need -2.8 deg neg camber, 6 deg pos castor, .3 deg toe out.
How much will that be?
Matt Vassallo
07-30-2005, 04:50 PM
yes i reccomend bill. he knows his stuff, good guy and alll that.
RussianKid
07-30-2005, 06:05 PM
dam man, when did it double?
call my cell so i can give it to you. sence some asses dont want me to stop by the shop ne more.
hachibill
07-30-2005, 10:00 PM
price is $75 a pop for just an alignment. more if other work needs to be done. if its just a toe set then only $50.
vBulletin® v3.6.10, Copyright ©2000-2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by
vBSEO 3.2.0 RC5
