View Full Version : lowering suby
fadedSTi
07-28-2005, 01:26 AM
im going to lower my suby soon. am i going to need an alignment right away?
FastRaft WRX
07-28-2005, 01:30 AM
ive heard its very strongly recommended..
fadedSTi
07-28-2005, 01:49 AM
did you do yours when you lowered it?
BrewPuBeaver
07-28-2005, 02:13 AM
you are going with the Tein springs right?
personally i would do the install and alighnment the same day.
your handling will be spot on, and you wont have any uneven tire ware.
fadedSTi
07-28-2005, 02:21 AM
no im going with the new perrin springs that come out next month
BrewPuBeaver
07-28-2005, 02:57 AM
well from what i hear from the guys at PDXTuning those springs are teh hotness.
+12 for the Latest & Greatest
are you doing the install yourself? if so do you have a spring compresor?
FastRaft WRX
07-28-2005, 04:34 AM
no i didnt have my aligned but I sure would like too...its needs it badly
Franklin
07-28-2005, 05:02 AM
Pay 120$ over at Firestone to get lifetime alignment anywhere in the USA.
fadedSTi
07-28-2005, 12:53 PM
how does it drive without the alignment? is it pulling all over the road?
DubtecV2
07-28-2005, 01:17 PM
Lowered my old car (not a Suby) and never got an alignment -- drove perfectly straight.
fadedSTi
07-28-2005, 01:40 PM
:thumbup:
JonLGT
07-28-2005, 02:25 PM
I did my springs on my own and never had to have it aligned.
fresh&clean
07-28-2005, 03:33 PM
Id get it aligned just to be on the safe side.........I mean its only like 60-80 bucks I think it wouldnt be a problem for you.
Don't half-ass it. If you're going to spend the money modifying your car, do it right else continue saving till you can. In an ideal situation, lowering the car would only knock out your camber specs but in reality since you will be unbolting the hub to get to the strut, chances are you'll be introducing some (minor) changes to toe settings. Will the car be undriveable afterwards? No, but you may experience some unnecessary tire wear (minor again) if the toe is off. And don't look at the alignment as being an expense, look at it as being a performance enhancement. You'll have the ability to set a more aggressive tune and get away from the stock settings.
JonLGT
07-28-2005, 08:28 PM
Are you planning on DIY or having them installed?
esemes
07-29-2005, 12:49 AM
let the springs set for about a week (or one day of agressive driving), and then perform the align.
even a completely oem sti could benefit from an align, after some miles....
ese
fadedSTi
07-29-2005, 12:50 AM
i will be lowering it myself. let the car settle for a week and then get the alignment done to make sure its ok.
Sounds like a plan.
:bigthumb:
Alizarin
07-30-2005, 03:09 AM
Mastro did an excellent alignment on my car after I put on the suspension, which I did myself. When we did it the guy helping me had a tool you put on one of the lug studs to let you reset the camber close to what it was with the new stuff on it.
I don't recall, but I really don't think they had to do much, aside from set it up for performance (I think I have -1.5* camber in the rear and -1* front)
SRQSTI
07-31-2005, 12:21 AM
If i lower my wrx do i need a camber kit or is a alignment the only thing i need?
Alizarin
08-01-2005, 07:15 PM
Depends on how far down it goes and how much camber you want. I believe that the -1.5* I got is the approximate limit of the stock camber bolts with the Spec C suspension I have, but I could be wrong.
SRQSTI
08-01-2005, 11:05 PM
i was thinking of getting perrin springs. should i get a camber kit?
fadedSTi
08-02-2005, 12:49 AM
i was wondering the same with my 05 STi. camber kit needed?
DubtecV2
08-02-2005, 03:26 AM
Camber kit? Nope....I have Perrin springs and the camber is just fine. Check my sig pic ;)
Alizarin
08-02-2005, 12:24 PM
It couldn't hurt. Always nice to have extra flexability. I don't think camber bolts are that expensive... camber plates, on the other hand, can be.
vBulletin® v3.6.10, Copyright ©2000-2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by
vBSEO 3.2.0 RC5
