View Full Version : who can build or tell me where to go for a custom box?
benberr3
06-10-2005, 05:08 PM
not sure of the system but just wondering who can give me some ideas on where to go for when i need a box
Notladstyle
06-10-2005, 05:09 PM
I'm sure there are 20 people in here who would build you a custom box for a 6pack. I dont drink but but ill build it for a 6 pack of mountain dew.
adero
06-10-2005, 05:41 PM
Your best bet would just be to make it yourself. it's cheap, and you'll defenitely benefit from learning how. just use 3/4" mdf bosrd, and get the internal volume to equal or be close to the recommended space for the sub, and then use pre-drilled 1.5" drywall screws and wood glue to put it all together. All you need is a jigsaw, and a drill, and ur set.
GsEclipse02
06-10-2005, 06:44 PM
whtmustang99 makes some nice box's ... pm him...
Notladstyle
06-10-2005, 11:29 PM
fuk wood glue, get silicon it will hold water
2fast4ass
06-10-2005, 11:39 PM
go to homedepot they make reall goood box give them the size u want and they make it for u they give u wat u want eny size or shape they make crazy shit
:-P :-P :-P :-P :nworthy: :nworthy: :nworthy: :nworthy: :nworthy: home depot lol
Notladstyle
06-10-2005, 11:44 PM
You've been toking without me?
TBSpyder
06-11-2005, 11:14 PM
If you want it professionally done, come by SoundAdvice...Dale Mabry & Columbus. We can do anything from a simple box made specifically for your sub(s) to a full custom enclosure. Ask for John and I'll give you a discount.
benberr3
06-15-2005, 09:53 PM
does home depot really build the box for you ?
TBSpyder
06-15-2005, 10:27 PM
Ofcourse not. They'll go as far as making the cuts for you, but I believe you usually still have to pay extra even for that.
integralsgreen
06-18-2005, 09:17 PM
i use wood glue to hold it together then silicon all the seams inside the box when im done
Notladstyle
06-18-2005, 09:58 PM
hey that works too, I just like the idea that my silicon is squishing together between those boards eliminating every milimeter of possible escape for the puny air molecules. leaving them helpless to resist the bone crushing high PSI factor that will slowly drive them into atoms as the bass pumps....
racingtheburg
07-08-2005, 12:14 PM
Need help with a box hit me up 727-412-2761 chris
kpr10is
07-08-2005, 03:44 PM
Wood glue is what actually holds your box together. Screws just let the wood glue dry. Please take a video of a sub blowing your box to pieces once it happens with only silicon :)
Home Depot sucks ass at cutting wood, and so does Lowes. At least every location its ever been to.
+1 to adero and john. Either DIY or get it done professionally.
scoobywrx
07-08-2005, 06:25 PM
Auto Audio on 19 makes boxes
Notladstyle
07-08-2005, 10:59 PM
Silicone is much stronger than wood glue once it dries. Even without the screws for support, I can jump on a siliconed box. Please take a video of you jumping on a box made with wood glue and no screws without breaking ;)
kpr10is
07-08-2005, 11:05 PM
This sounds like it could be an interesting test. It might be worth the $20 in wood and take some videos, see how much weight each will hold. Hmmmm
TIM TIM TIM
07-09-2005, 02:56 AM
pm me, Buy the wood and give me 15 bucks and ill do it. I usually use staples from an air staple gun with wood glue then calk (sylicone based) for all of the seems. havent had one come apart yet.
integralsgreen
07-09-2005, 11:38 AM
dont know what kinda wood glue your usin but usually the wood itself will break befor the seal between the 2 glued peices will.
TBSpyder
07-09-2005, 03:19 PM
Exactly. I've yet to see silicone caulk outperform wood glue.
integralsgreen
07-09-2005, 05:13 PM
btw dosent silicone flex? i use liquid nail and if you were to jump on it the wood would simply snap befor the it will come unglued. silicone is good to keep it airtight after its glued together but i cant see it holding anything together.
Notladstyle
07-09-2005, 06:12 PM
i have no wood glue to test that, but as soon as it stops raining ill video my 170+ lb self jumping on a silicone box with no screws.
kpr10is
07-10-2005, 02:44 AM
So....
No mounting rings. Silicone. Whats next?
lol jfwy man
TIM TIM TIM
07-10-2005, 02:48 AM
silicone is deff. not as strong as wood glue. You may be able to jump on it but if you compare to evenly built boxes, one with wood glue and one with silicone, the wood glue will WAY out do it. as said above, its stronger then teh wood itself. For real though, If you want me to make you a box i can do it. just buyt he stuff
My ported box is held together entire from glue, and silicone for the sealing... I can jump on it for sure.
integralsgreen
07-10-2005, 11:27 PM
So....
lol jfwy man
+1 dalton likes to do things his own way
Notladstyle
07-11-2005, 04:00 AM
So....
lol jfwy man
i filled my wheels with water once...
integralsgreen
07-11-2005, 07:56 PM
:wtf:
Notladstyle
07-11-2005, 10:30 PM
:wtf: didnt work well, lets not talk about it.
crazyeclipse66
07-13-2005, 01:43 PM
would a jigsaw cut out the circles for the subs or would u have to use a rotary saw?
if by rotary you mean circular saw?
I use either a jigsaw or my router
TIM TIM TIM
07-13-2005, 04:57 PM
I always used a jig saw
vBulletin® v3.6.10, Copyright ©2000-2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by
vBSEO 3.2.0 RC5
