View Full Version : Fuel Cut Defenser
MightyMaxGS-T
06-02-2005, 10:40 AM
hey i got a j&s fuel controller works the same as a Fuel Cut Defenser...i have a mitsubishi and i can't do anything with it, and i know u guys can use it. So....it's up for sale
Slash
06-02-2005, 05:20 PM
I'm assuming that these things are tailored for the application and thus wont fit any toyota vehicles....
MightyMaxGS-T
06-02-2005, 10:29 PM
what? why do you think i posted it in here, it can be used on any car that needs it.
Slash
06-03-2005, 12:37 AM
Got a link to a website for the manufacturer that says teh same thing? Sorry i just havent heard that the FCD's are interchangable between cars. I'll eat my words however with a simple link or web page :)
MightyMaxGS-T
06-03-2005, 01:16 AM
This is straight from the manufacturer:
Chris:
That unit is similar to an HKS "Fuel Cut Defenser", except it works much better. It's an adjustable voltage clamp, used to prevent MAP sensor codes or fuel cut when the using a stock MAP sensor.
Red and Black are 12v and ground. The other two wires were usually Green and White, but I made some with Blue and White, depending on what wire I had in stock at the time.
To install, first turn on the key, and measure the stock MAP sensor voltage, and write it down.
Key off, then cut the MAP sensor wire near the ECU.
Connect Red to switched 12v, and black to ground. Temporarily connect the Green to 12v as well.
Now, turn the key on, and the LED should be on, indicating that the unit is clamping.
Measure the voltage coming out of the White wire. Turn the adjustment until thevoltage reads what you previously wrote down.
Key off, and connect the Green wire to the MAP sensor output.
If the MAP sensor outputs too much voltage under boost, the unit will clamp it to stock value, preventing codes and fuel cut.
John
hachibill
06-03-2005, 11:04 AM
it says MAP sensor, is it compatable with a MAF sensor as well?
MightyMaxGS-T
06-03-2005, 01:59 PM
it was on an mr2
vBulletin® v3.6.10, Copyright ©2000-2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by
vBSEO 3.2.0 RC5
