PDA
View Full Version : Low Budget Subs
DubDaze
04-24-2005, 12:44 AM
I Just Applied for a job at publix so ill have extra cas to spend. well all the money i make ill be able to spend on w/e but i have 2 rockford 15" series 1, there old and they hit pretty good for beaing old but now its time to upgrade. i have a 760w pioneer amp. and i dont really want to buy another but if i HAVE to i will try .. so here are the subs im lookin into buying i want 2 of them
http://images.cardomain.net/products/abn/ABNAW1000Q_1.jpg
Subwoofer Specifications
Rec. Sealed Box Dims: 0.25 - 0.75 cu.ft.
Rec. Ported Box Dims: 0.65 - 2.35 cu.ft.
Free Air Usage: not recommended
Sensitivity: 91.1 dB
Frequency Response: 23-500 Hz
Recommended RMS Power: 600W
Peak Power Handling: 1200W
Magnet weight: 140 oz
do you think i could run 2 of these off my 760w amp?
93ex
04-24-2005, 07:57 PM
you could run anythign off your amp, but audiobahn sucks and dont waste your time.
try image dynamics ID 10's
Bumpin Expo
04-24-2005, 08:55 PM
so you want to upgrade from 2 15's to 2 10's audiobahns? Dont know how the old RF subs are but that sounds like downgrading to me
Try www.edesignaudio.com. Check out the O or A series
DubDaze
04-25-2005, 06:51 AM
yes my 15's are pretty old , they have great SQ, but a tiny magnet.
03AcuraCLTypeS
04-25-2005, 08:09 AM
i know where u can pick up 2 10" 1200 watt rms sub for 89 a piece brand new
Srt4Viper
04-25-2005, 10:11 AM
i bout 2 type r 10"s from CC for 100 a peice and i they got loud and sounded great
DubDaze
04-25-2005, 02:31 PM
im lookin into some MTX 5500 12"s
cLined
04-28-2005, 12:50 AM
I have 2 MTX 12's = mint condition...
adero
04-28-2005, 08:35 AM
I have a pair of 10" Image Dynamics IDQ's that are SVC 4 ohm. shoot me a pm if ur interested
obie
05-01-2005, 05:18 PM
Audiobahn with the flames is the hawtness!!! What are you looking to spend? Get two IDQ10D2's.
TJElite
05-02-2005, 05:49 PM
We sell Audiobahn, and just put two of those 1000Q's into a ZR-1 with about 500 watts going to the pair. It is quite loud, and gets down quite low. I did a single 1200Q in my wife's escalade on about 800 watts, and it works well, also. I hear a lot about Audiobahn not being any good, but it works well for me.
I also sell Crossfire, and they have a new entry level line called Distinct Audio. I sell the Distinct 10's for $99 a pair, and they're good for 150 RMS, 450 max. Dual 4 ohm coils. I'm putting 4 of them in a Caprice wagon on a 4x125 Distinct amp. We powered it up a couple weeks ago, just to hear them, and they were damned impressive! All 4 are in about 3 cubes, sealed. They hit hard, get down low, and sound very smooth. Lots has been lost, imho, on these new, big power, high excursion subs. Yes, they'll take lots of power, but they'll need lots of power to get loud. And standard 1w or 2.83 V at 1 meter efficiency readings don't mean squat...most of them are at 1khz...useless for a sub.
Back in the late 80's, nearly every 'loud' car had a punch 150 (a whopping 180 watts mono) and a pair of punch 12's. Most of them were truly loud and sounded good, too. And you didn't need 3 extra batteries, 2 caps, and 1/0 wire. Sure, they weren't 160 db, but I did 134 with mine, on the old IASCA DB test track (for those who don't remeber it, it was far from 50 cent).
I've got nothing against big systems, though. My other Caprice (91 sedan) has two Lightning 12's on a lightning 1000 watt class D, with an 800 watt staggered amp running the mids and highs (14 of them). It also has a 225 amp alternator, 250 amp isolator, 1/0 cable, a Yellow Top, and a 25 farad cap.
For anything but a sound off pounder, give me a couple 10's in a sealed box, with 250-500 watts on the pair, a couple sets of seperates, and a good head unit.
Maybe I'm just getting too old.
Toby J
T&J Elite Customs
Oldsmar, FL
mustangman98
05-03-2005, 06:01 AM
you will be dissappointed with 10's f your used to the 15's....
i had a set of Kicker Comp vr series sub's in my old explorer, hand made ported box and a rockford fosgate 500.2Power amp that pushed out 714 watts according to the birth cirtificate. also had a Tsunami 1.0 farad capactior....
that combo hit 154.2db in an audio competition and set a WV state record that held for 2 years and i had about $800 in the entire stereo system.
then i went to a mustang and went with 2 10 Compvr's and hit a whooping 141.0 in a custom box with the same amplifer and set a Fl state record cause the amp was rated at 300rms.
can't miss with Kicker, good quality and been around for a while. you wont be disappointed with the comp vr series. i think the 10's go for about $60 a piece, $75 for 12's, and $125 for 15's.
adero
05-03-2005, 08:52 AM
154.2 with what? did u place the mic inside the port or something? plus, it's a birth sheet, not a birth certificate.
stealthc9
08-18-2005, 08:21 AM
300watt rating umm dude the street class A record is 146.9 before talkin anything research ur factsyou will be dissappointed with 10's f your used to the 15's....
stealthc9
08-18-2005, 08:22 AM
scan the "birth certificate" for that post it on here please
Notladstyle
08-18-2005, 01:07 PM
+1
pwnage
Eclipse99RS
08-20-2005, 03:39 AM
i highly doubt that you could hit 154 db with to kicker vr's, and only a 500 watt amp. thats almost as funny as the kid with 2 12's that told me his system could hit 195db.
izzyaccord
08-25-2005, 12:21 PM
i got set of 12 audiobahn aw1206 model older flame series sub they hit hard ass hell
aaron1017
08-26-2005, 02:19 AM
I'd get the Elemental Design K series. My sister's older e12k flatcone has a fair ammount of sq and spl for the money spent.
