View Full Version : capacitor wiring
DubDaze
04-21-2005, 05:55 PM
My friend needs me to hook up his 2 poineer 12's his amp and a cap, and the only thing im not sure of how to do the the cap? can someone find a easy diagram to read or draw one? thanks for the help.. :nworthy:
DubDaze
04-21-2005, 06:15 PM
http://img.photobucket.com/albums/v209/s2kownerx11/CapAmpWiring.jpg
DefiantGuy
04-21-2005, 06:33 PM
you can run the ground from the amp to the ground of the cap and just ground the cap, you also don't need a ground to the cap from the batt either
DubDaze
04-21-2005, 06:53 PM
aight thanks
DefiantGuy
04-21-2005, 07:39 PM
i mean neg to the cap from the batt
DubDaze
04-21-2005, 07:41 PM
aight thanks for clarifying
TBSpyder
04-21-2005, 09:53 PM
If the cap is new, you know you need to charge it right?
DubDaze
04-21-2005, 10:25 PM
yes buy i was gonna read up on that, but can you tell me how? this is what i thought was run the cap without the amp for liek a hour untill it charges? but idk :dunno:
TIM TIM TIM
04-21-2005, 10:36 PM
usually it comes with a small light or the cheaper ones just have a little wire thing you use.. basically with wiring it, just go from battery to cap to amp with power, and negative you can run to the same place as the negative of the amp, or connect them, whichever is easier.
DubDaze
04-22-2005, 08:34 AM
how on gdo i do that for? i rea dabout the ones with a light some say 3 minutes?
DefiantGuy
04-22-2005, 11:34 PM
you can buy a resistor and put it inplace of your fuse in your fuse holder....when you power it up it will charge slowly that way
vBulletin® v3.6.10, Copyright ©2000-2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by
vBSEO 3.2.0 RC5
