what car is this?
Old Apr 18, 2005 | 09:47 AM
adrian_302's Avatar
Caribbean Queen
Default what car is this?
i was on i-4 today omw to work when i get behind this VERY nice looking sports car. i didnt recognize the badge, it looked like a bentley logo without the B in the middle. the only other badge was on the right side of the rear end that said "V8 9" or "GT 9" i cant quite remember, all i know is that once traffic cleared up that thing picked up and hauled ass. it had a crossfire look to it but it didnt have the chrysler logo. does this sound familiar to anyone?
formally known as d33flat
1991 nissan 300zx - Sold
1989 240sx sil80. not stock anymore yay!(dead in the driveway)
2005 Dodge SRT4 (new DD!)
Old Apr 18, 2005 | 09:53 AM
F*r*a*n*k*e*i's Avatar
I've seen a few of those. No idea what it is, but man, they're cool looking!
Old Apr 18, 2005 | 10:24 AM
Fatalia's Avatar
Unnecessarily Necessary
It was me.
www.myspace.com/fatalia
Old Apr 18, 2005 | 10:26 AM
adrian_302's Avatar
Caribbean Queen
Originally Posted by Fatalia
It was me.
damn that subaru looks hotter in person then
Old Apr 18, 2005 | 10:28 AM
Fatalia's Avatar
You're damn right it does.
Old Apr 18, 2005 | 10:42 AM
g-50Cab's Avatar
TR Balla Donor Supreme
That's an easy one - Aston Martin
Logo
Bentley Logo
DB9
I like the v-12 vanquish my self...
Old Apr 18, 2005 | 10:44 AM
Orion ZyGarian's Avatar
7M 2JZ bird in pear tree
Nice! I wouldntve guessed that...
...of course, I've seen one in sarasota and knew what it was when I saw it; its much harder to describe something than show a pic
I think theres a GT V8 or something, a more kickass factory version?
ASE: Brakes
Old Apr 18, 2005 | 10:45 AM
g-50Cab's Avatar
Old Apr 18, 2005 | 10:47 AM
g-50Cab's Avatar
Specification
Body
Two door coupe with 2+0 or 2+2 seating
Extruded aluminium and carbon fibre bonded body structure
Composite front and rear crash structures
Aluminium and composite body panels
Extruded aluminium door side impact beams
Engine
All alloy, quad overhead camshaft, 48-valve, 5935cc 60° V12 front engine, rear-wheel drive
Twin PTEC engine management system controlling fuel-injection, ignition and diagnostics
Fully catalysed stainless steel exhaust system with active by-pass valves
Compression ratio: 10.8:1
Maximum power: 388 kW (520 bhp) at 7000 rpm
Maximum torque: 577 Nm (425 lb.ft) at 5800 rpm
Acceleration: 0-100 km/h (62 mph) in 4.8 seconds; 0-160 km/h (100 mph) in 9.8 seconds
Maximum speed: Over 321 km/h (200 mph)
Transmission
Six speed manual transmission with Auto Shift Manual/Select Shift Manual (ASM/SSM) electro-hydraulic control system
SCP/CAN interface to engine management control system
Limited slip differential. Final drive ratio 4.30:1
Steering
Rack and pinion, variable power assistance, 2.1 turns lock to lock
Column tilt and reach adjustment
Suspension
Front: Independent double aluminium wishbones
Coil springs, monotube dampers and anti-roll bar
Rear: Independent double aluminium wishbones
Brakes
Teves vacuum assisted Antilock Braking System (ABS)
Electronic brake and engine intervention traction control system
Front: Ventilated and grooved steel discs 378 mm diameter with six piston calipers
Rear: Ventilated and grooved steel discs 330 mm diameter with four piston calipers and separate handbrake caliper
Wheels & tyres
Lightweight aluminium alloy wheels
Front: 9J x19
Rear: 10J x 19
Yokohama tyres: Front 255/40 ZR19/Rear 285/40 ZR19
DB9 Specs
Body
Two door coupe or convertible body style with 2+2 seating
Extruded aluminium bonded body structure
Xenon gas discharge projector headlights (dipped beam), halogen projector headlights (main beam) with power wash
LED rear lights
Engine
Mid-front mounted, rear wheel drive
Engine management system with Neural Net misfire detection system
Compression ratio 10.3:1
Maximum power 335 kW (450 bhp) at 6000 rpm
Maximum torque 570 Nm (420 lb ft) at 5000 rpm
Acceleration (Coupe manual) 0-60 mph in 4.7 seconds 0-100 km/h in 4.9 seconds
Acceleration (Coupe automatic) 0-60 mph in 4.9 seconds 0-100 km/h in 5.1 seconds
Maximum speed 186 mph (300 km/h)
Transmission
Rear mid-mounted 'Touchtronic 2' six-speed gearbox with electronic shift-by-wire control system
Rear mid-mounted six-speed manual gearbox
Final drive ratio 3.07:1 (auto) 3.54:1 (manual)
Steering
Rack and pinion, Servotronic speed-sensitive power-assisted steering, 3.0 turns lock to lock Column tilt and reach adjustment
Suspension
Front: Independent double aluminium wishbones incorporating anti-dive geometry, coil over aluminium monotube dampers and anti-roll bar
Rear: Independent double aluminium wishbones incorporating longitudinal control arms, coil over aluminium monotube dampers and anti-roll bar.
25psi's Avatar
Treated and Released
They make a V8 Vantage(Soon, I don't think that is out quite yet), DB 9, and the Vanquish....which has a hi-performance "GT" package.
-Jim
“Equality, rightly understood as our founding fathers understood it, leads to liberty and to the emancipation of creative differences; wrongly understood, as it has been so tragically in our time, it leads first to conformity and then to despotism”-Barry Goldwater
