PDA
View Full Version : Directions to Deland?
jaball77
04-16-2005, 06:44 PM
It looks like CFRSolo2.com is down and I didn't print out the flyer for this weekend's Deland event... Anyone have the flyer, or can you post directions to the Deland site?
Thanks!
mrf582
04-16-2005, 09:38 PM
here's the postal address. use mapquest
1500 Matt Fair Blvd
Deland, FL US
mofugga
04-18-2005, 11:23 AM
did you find it? how'd the miata work?
jaball77
04-18-2005, 12:19 PM
Yeah, we found it fine. Not a bad site. Dunno if it was worth a 2 hour drive...
The Miata, well...
I think we have a fuel starvation problem. Coming out of the u-turn it hesitated for a second, then took off again... It does it on hard acceleration in 1st gear, too. Bizarre. :-(
Oh, and it needs shocks. BADLY, haha.
platinum703
04-18-2005, 05:51 PM
were you running on under 1/4 tank of gas?
that could be the problem, although i have never experienced that problem in my 94 and always run with under 1-4 tank.
btw konis rule!
-trey
Loren
04-18-2005, 07:33 PM
I've heard of a bad fuel pressure regulator causing that kind of problem. Also... are you sure it's fuel starvation? Miatas are notorious for eating plug wires... could be an intermittent plug wire.
jaball77
04-18-2005, 08:38 PM
It did it both on an almost empty tank (at the autocross) and on about half a tank (when I got home).
It's not the wires... Stu put a new set of NGK blues on it for me...
The battery wasn't secured too well, so I stopped by Pep Boys and bought a generic tie down kit which does NOT fit well with the Miata battery setup, haha. But I jury rigged it in there... I also made sure all the plug wires were tight at both ends...
Now, I'm not sure if it was the battery sliding around, or the wires, or the battery being disconnected and resetting the ECU, but the damn thing ran perfectly. I let it warm up, then flogged it around town for about an hour and it was dead solid perfect.
Absolutely BIZARRE.
I guess I'll look up the FPR in my handy dandy Rod's 1.8L manual tonight, haha.
platinum703
04-19-2005, 02:22 AM
well thats good to hear if you plan on making the gville event this weekend- ill be looking for another set of tires to borrow like I did last weekend...
...wish me luck
new tires or not I always seem to do poor at GIR
jaball77
04-19-2005, 07:09 PM
As much as it kills me, I'm gonna have to pass on G-Vizzle this weekend. Jeremy and I are gonna try to get some brakes on the car... And the Konis are in the mail!
Leonard
04-19-2005, 07:24 PM
Looks like I won't be able to make Gainesville either. The Koni's just came in yesterday, but I won't be able to get the rear upper mount welded in by Sunday. If I can retrofit the old mount to work, I might make it, but that's not looking very likely.
platinum703
04-19-2005, 08:13 PM
well, i did locate some slightly used azenis, so hey- I will be at g-ville, and hope to see you guys if i can start making the brooksville events. its just hard to justify when im all the way up here in south georgia (aka tallahassee).
IRCC is a straight shot from my parents house in Sebring (about 1.5hrs) , and being a 2 day event with practice on saturday i can justify spending one weekend a month with the 'rents to get 2 days of smooth pavement (ever been to a dixie region event?)
Gville is only 2 hours, (the sebring event is 10 miniutes from my 'rents house) and i have a place to stay in DeLand. I just need to make some friends that live closer to the brooksville course, i guess ;) then ill have ALL my ducks in a row! (thank you miata for sipping gas)
