dash lights
Check relays and check the actual lights behind the display. Go through everything systamtically and you should find your demon.
There are points in life where one looks at his or her situation and says "how the fook did i get here?" ... this is one of those instances....
I don't know about an Altima but on most cars, and the 240, the tail lights and cluster lights are on the same circuit so if you have a tail light out you will know. It won't affect your brake lights just the rear parking lights. Check your tail light fuse and also to see if your tail lights work.
