View Full Version : New to gm
Maite
04-06-2005, 08:28 PM
I was thinking about getting a 00-02 ls1 fbody. I do not want to get 98-99 due to piston slap issues. Anyway I wanted to go with heads & cam , an auto with a 3200 stall (TCI?) some LCA's ,SFC ,fast intake ,ported TB, lid. longtubes (qtp's?) and dumps? I am also interested in spraying the car with a 125 shot. What are your thoughts? ls1 powah :nworthy:
Guado
04-06-2005, 10:09 PM
ge an 01+ more hp outta the box and no EGR. Also I do believe the 01 and 02 had piston slap too. :D
JuicedSS262
04-07-2005, 08:42 AM
Perhaps two 125 shots would be better no?
Can't wait to see you out laying the smack down on those poor lil unsuspecting 03/04 Cobras.
corey r.
04-07-2005, 11:14 AM
I would not worry about that at all. I have almost 130k on my daily driver 98 and it runs like a champ!
want2speed
04-07-2005, 02:41 PM
Same here, '98 SS with almost 90K miles and there isn't a bit of internal sounds or trouble ... The only issues I've had are identical parts as any newer ones ... Water Pump, Differential, etc.
And .. they're cheaper than the 00-02 :wiggle:
corey r.
04-07-2005, 02:51 PM
my window needs a new motor.. :(
want2speed
04-07-2005, 10:36 PM
Corey R ... not trying to change the subject of this thread but ... I ordered this one from ebay.
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1&item=7966226677&category=33706
It's the upper end of the two types that they have, I ordered one myself for the drivers side and it works great. They offer 2 different types but the other is an import that is cheaper. A friend ordered that one and the cutoff didn't work properly and cracked the inside of the door ...
corey r.
04-08-2005, 01:31 AM
shit dude thats cheaper then advanced auto parts... thanks for the link..
/hijack
Tackleberry
04-08-2005, 03:20 AM
new to Gm huh....buy a bottle of valium...your gonna need it
Rolling Thundah
04-10-2005, 05:32 PM
Maite thought you were going with a procharger 408 combo?
Sneakin Deacon
04-10-2005, 06:47 PM
for an LS1, to boogie the hell out...from a dig
#1...buy a rear end! (go with like a 3.55 gear and locker, 35+ spline axles w/ ARP extended studs) do LCA relocation brackets etc at this time too!
#2 15x8 draglites/prostars/etc w/ 28x9x15 ET Drags
#3 TH400 w/ 3500-4000 stall (tall tire and gear sorta help highway cruising)
#4 torque arm
#5 SFC's
#6 DSL
#7 nice driveshaft
(i doubt ANYONE will say do those mods 1st, but if i ever get another fbody, unless its an m6 i will put a th400 in it, you will get your biggest problems and headaches out of the way, and save alot of money in the end imo...new rear ends, and constant tranny rebuilds and downtime will be nullified)
#8+ depends on what you wanna do, if your going to be on motor/juice, i say get a LM juggernaut cam, and maybe toss a little 50 shot on it. youd definately be in the 500 range and solid 10's, with just cam and regular boltons on stock heads. as for longtubes i like the dynamaxx(i think thats them)
Rolling Thundah
04-10-2005, 07:39 PM
Kenny maite is serious about a high 9 low 10 second street car, I think some of your suggestions may help her. I told her get a skeleton and build it up!
Maite
04-10-2005, 08:35 PM
I want to run a T88 turbo and some spray from 4k to 5500rpm to get my automatic with a 4k stall going out of the hole. I'd like to run 3.23 gears, with 28inch slicks on 15 inch wheels. I would like to do a similar suspension setup like HybridSS, but I want bogart wheels. I want to add bore and stroke 4.125 x 3.70(offset grind). I'm looking into getting a 396ci Darton Wet Sleeve hydraulic roller engine...
Rolling Thundah
04-10-2005, 09:01 PM
Maite your ideas are refreshing to the GM section , I heard via the grapevine your shooting to take out Datruth, onesweet, juicedss and Hybridss . Any truth to this?
Maite
04-10-2005, 09:03 PM
Maybe... :)
HybridSS
04-10-2005, 09:15 PM
Bring it on!!! You know you will get an asswooping!!!
Rolling Thundah
04-10-2005, 09:16 PM
Race Al right now!!!!!!!
LOL !!!!
Maite
04-10-2005, 09:21 PM
:rolleyes: Dream on. You tried once and lost. Don't deny it.
Rolling Thundah
04-10-2005, 09:23 PM
Al , Maite told me she would beat you so bad that you would think you were driving Shalane's car instead of yours!
Rolling Thundah
04-10-2005, 09:25 PM
Al, Maite told me that she would whip you so bad that you would think you were driving Shalane's car instead of yours!
DaTruth
04-10-2005, 10:01 PM
I would love to see another female in the mix.. Shalane would finally have some competition..
HybridSS
04-10-2005, 10:13 PM
maybe I let you win :-P
Maite
04-10-2005, 10:31 PM
Living in denial must be nice...
HybridSS
04-10-2005, 10:35 PM
Your right...Im wrong. After seeing you almost rip some womans head off the other night for putting mayo on your burger:flamed:...I dont want to get on your bad side. :whoa:
You win you win!!! :blackeye:
HybridSS
04-10-2005, 10:45 PM
Now...Maite...stop hijacking your own thread before I lock it down. :-P
Rolling Thundah
04-10-2005, 10:50 PM
Wow getting hot just for mayo, your hanging with Shalane too much!
HybridSS
04-10-2005, 10:54 PM
If that was Shalane...the waitress would have a smoldering stump where her head once was.
Shalane when angry --> :evil4:
Rolling Thundah
04-10-2005, 11:06 PM
Yes Al I know, when she found out her car was not an Lt1 she went mad , mad I tell you!
Maite tell us more about your set-up!
Sneakin Deacon
04-10-2005, 11:37 PM
have we met before :haha:
well, im not sure what sorta budget you are working with, but form the sounds of it, money isnt much of an object. and the fact you want a turbo, :)
anyways - my suggestion
i stand by all of my suspension suggestions unless you wanna go to a larger rim, say 15x12 since were talkin some serious power now. i would say definately tubular k-member and the rest of BMR's associated parts to lighten things up some.
C5R block (blast from the get go :D ) forged through and through
heavily ported heads of your choice (you can go for a little more volume and a little less velocity, as you'll be pressurizing the intake, and it should compensate)
contact alan futural for a cam (or anyone else with the software he uses)
as for turbo selection, T88 is weak sauce. Precision's PT96 Thumper with 1.00 A/R (should spool just nicely with the stall you are wanting to use, while being able to support 1500+rwhp) and of course, this means an air/water intercooler, most likely an in-dash one.
now, for the big question...do you want to run a wheelie bar? cause if not, i got a feeling this thing may be lifting the wheels quite high, and doubt skinnies and k-member will like a 5ft drop.
Rolling Thundah
04-10-2005, 11:39 PM
Her budget including car she told me is 38k, not a DD either.
DaTruth
04-10-2005, 11:45 PM
Thats a good budget, but what is a DD?
Sneakin Deacon
04-10-2005, 11:48 PM
alrighty, 38k budget. anyone wanna price this out?
shell - 5000?
28x9x15 MT Drags - 350
Bogart rims
ford 9" 40? spline setup with spool. - 2800?
C5R block
rotating assembly
PT96 - 2000
heads massaged - 3000?
cam - 350
intercooler - 500?
piping - 3000
BOVs,Wastegates - 600?
k-member setup
engine management(BS3?)
driveshaft
built th400 w/ stall
shifter assembly
SFC's
DSL
torque arm
xtreme drag rear swaybar - 400
shocks/struts - 650
misc shit you will run into - 1500
im probably leaving some stuff out for sure, but i think that should be a relatively close start, if anyone wants to add prices and see where this budget is gunna be.
Rolling Thundah
04-11-2005, 12:03 AM
DD daily driver
HybridSS
04-11-2005, 12:10 AM
I think you should buy a Volvo....they are safe. Then slap some NAWS on it!
Sneakin Deacon
04-11-2005, 12:14 AM
88 740 GL Volvo Wagon...it has enough engine bay for an LSx engine, TH400 and a ford 9". only problem being you wouldnt have the only one around town.
Sneakin Deacon
04-11-2005, 12:15 AM
now is this the young lady who drives the black vette, and her dad is like yz250 or something?
corey r.
04-11-2005, 11:43 AM
Oh God, here we go!
http://www.revxtreme.com/forums/images/smilies/leghump.gif
DaTruth
04-11-2005, 01:49 PM
This one looks 100 times better and has a booty:)
Sneakin Deacon
04-11-2005, 05:42 PM
oh, nvm, obviously way out of my league.
Rolling Thundah
04-11-2005, 06:15 PM
Vince making some obvious observations!
Maite
04-11-2005, 07:29 PM
I'm backing away... very....very...slowly...
shalane
04-11-2005, 07:34 PM
That's right beyotch, I still love you in that kinky way too!
Sneakin Deacon
04-11-2005, 07:59 PM
so, who will be the first to touch the lobes on my camshaft, i promise i wont put it in the bottom end, chances are ill knock the cam bearings out of it, no matter how much lube gets put on.
so umm yea...lol no one has any pricing input?
JuicedSS262
04-11-2005, 08:06 PM
Kenny Kenny Kenny
You dirty little boy.
So this Maite (how DO you pronounce THAT) wants to take me out too huh?
Well, quit the shit talking and BRING IT.
:fart:
Sneakin Deacon
04-11-2005, 08:19 PM
its pronounced maite...duh...
Rolling Thundah
04-11-2005, 08:29 PM
Pronounced Mi Tai, lol !!
Content Relevant URLs by
vBSEO 3.2.0 RC5
