PDA
View Full Version : using nitrous , breaks up ..
TSX24L
04-02-2005, 08:50 PM
When using the nitrous it breaks up around 5grand. What would cause this? Would fuel pressure cause this? Iam still using the stock fpr. I have aeromotive one to install, just having trouble installing it. What would be some other things to check out?
Josiah
04-02-2005, 10:11 PM
thats one of the first things I would check,whats your A/F like around that point, even a narrow band should give you some idea, get a A/F gauge, your probably lean as hell and lucky you havent blown your engine
Ian MMF
04-03-2005, 03:13 PM
What kind of kit? What Jets? What car? What mods? blah blah blah. Be more specific so we aren't chasing our own tail forever.
DANGERANGER
04-03-2005, 04:18 PM
Timing, engine condition,etc. Wht he said above me too, need more info to better VR diag.
Frank
Enhanced Concepts
727-638-4667
TSX24L
04-03-2005, 08:23 PM
I have a air/fuel gauge hooked up. Its staying in the rich side very rich the whole time. Moves up somewhat when the nitrous is in use.
Car is a 91 crx with a d16y5 block and y8 worked head. Stock internals. Iam pretty sure its getting to much fuel.
Josiah
04-03-2005, 11:56 PM
yeah, flooding can be as bad a problem as running lean, too much fuel
HybridSS
04-04-2005, 01:44 AM
gap the plugs tighter as well.
TSX24L
04-04-2005, 10:41 PM
what should I gaped them to? Do I use colder plugs? My timing is set to 16 degress. Should my timing be retared?
DANGERANGER
04-04-2005, 11:02 PM
Retard timing .5 degree for every 25hp shot. Gap plugs at 30 1 heat range colder regular NGKs no platinum.
Frank
Enhanced Concepts
727-638-4667
Josiah
04-07-2005, 10:13 AM
install the aeromotive as well, I dont know too much about nitrous...but I was under the impression you need that 1:1 regulator....
integra
04-07-2005, 06:12 PM
More Nitrous
Josiah
04-07-2005, 11:07 PM
true, that makes sense....too much fuel...add more air, or turn down the fuel at that point however your managing fuel
TSX24L
04-08-2005, 08:28 PM
matt what shot should i move up to? what would be the next step up?
Josiah
04-08-2005, 10:58 PM
still better to tune your fuel down before you step up the nitrous...otherwise you'll be running lean at other areas in the powerband...lean=detonation
integra
04-12-2005, 12:34 AM
go big or go home
Josiah
04-12-2005, 02:55 PM
go big and blow up your motor...get some decent fuel managment first
integra
04-25-2005, 01:30 PM
im pretty sure he has the right stuff for fuel because i have seen the car and know what he is working with.
Sneakin Deacon
04-26-2005, 03:47 PM
guessing its a wet kit, so what are your current pills at? sure you have the fuel pill in the fuel line and the n2o pill in the n2o line?
TSX24L
04-30-2005, 11:25 PM
Threw the rod. It was on 120 shot. I over reved. Didn't bogged dwon though and was alot faster then before. I need another block. I think I got it just right this time. It would probably be alot closter to 11.98 on the MT's. Pretty impresivie for being a sohc with minor head work and stock vavletrain. Now iam really addicted I just have another project to finish since my hf is about had it in my daily driver before I can start back on the race car.
If I don't decide to sell it all to finish my new motor. Well see. Its exspensive when you build cheap and fast.
