PDA
View Full Version : 2.0L Cams in the Srt-4?
Skittle
03-28-2005, 07:15 PM
What's all this about,i read about it awhile back,but i wanna know if any gains can be had,and whats the difference?Also does anyone know the Lift/Duration specs on the 2.0L and 2.4L turbo cams?
cali
03-28-2005, 07:18 PM
I hear there are gains, but they jury is out on setting them up....
Big Yeller skittle Riven, did u put em in yet?
Skittle
03-28-2005, 07:31 PM
Awaits for Rivens reply :-)
B20VTECpoweredEG
03-28-2005, 09:13 PM
Is the cam journals the same in the new gen 2.4's as older 2.0 neon and 2.4 caravan motors?
Josiah
03-29-2005, 10:43 AM
yes, all 2.0DOHC and 2.4 use the exact same head, the 03-up head is just a different port design with a different oil return passage, the rest of the head is still the same
Skittle
03-29-2005, 02:42 PM
Know any cam specs?...I'm thinking about doing this,plus the 2.0L cams are cheap,and readily available
Josiah
03-29-2005, 10:05 PM
I know, I have a spare set sitting in the back of my car right now...I see a whole lot of posts around on the subject, but no real evidence of whether they help, they are almost certainly better than the stock SRT4 cams though(which I'm pretty sure chrysler just used from the NA 2.4 motors) they have a somewhat higher powerband and more lift than all stock 2.4 cams except maybe the 96 2.4 cams(have an extra set of those too) I would use one of those sets myself except I thought I should get some use out of my #14s after what I paid for them, but check on neons.org or srt4forums.com for many many speculation threads with no real evidence
Skittle
03-30-2005, 02:11 AM
If you wanna sell your 2.0 cams let me know :-)
riven
03-30-2005, 07:05 AM
Whats the point. I would cost 10x more to put them in, then the cost of the cams alone.
Josiah
03-30-2005, 07:54 AM
sure $40 is all I want for them, he right though, you would probably want to install them yourself, otherwise a shop is gonna charge you an arm and a leg
riven
03-30-2005, 01:07 PM
unless you are experienced retiming the engine, dont think about it.
cali
03-30-2005, 07:06 PM
setting timing is pretty easy, just read the book, take your time
riven
03-30-2005, 07:11 PM
well then cali ole bia, come time my car :)
cali
03-30-2005, 08:15 PM
Install the cams, I'll set your timing to factory specs
Josiah
03-30-2005, 09:14 PM
timing is a cinch, done it a half dozen times on my car, and just so you know, I am using SRT cam gears, water pump, timing belt and timing belt tensioner...so yes the procedure is the same, its easy...just takes a few tries
Fast420A
03-30-2005, 10:24 PM
I changed the cams on my 420A powered Eclipse with a set of Crane Regrinds a few years ago in my driveway with just hand tools. I even figured a way to do it without removing the timing belt and cam gears. Zipties and white out for marking the cam gear and belt position are your friends. It can be and has been done by a few 420A people so it shouldn't be a problem to do it yourself.
Josiah
03-30-2005, 11:55 PM
heh, the old bungee cord trick? no but if your doing it anyway, might as well change your timing belt, even if you only have like 10 or 15k miles on it, after all, it will be 10 or 15k miles more before you have to do it again...thats a years worth of driving
