marksaccord95
03-26-2005, 05:37 PM
Sw20 MR2 short stroke AGXs for the front, cutting the strut tubes down 1.8" then apply welded on ground control coilovers, 8kg
rear, T3 coilover conversion, 6.5kg, should be here tomorrow or the next day
then for camber im probably gonna get some LCAs from a junk yard, modify them with a heim joint, cheaper and more adjustable then camber plates.
might do 4 link and laterial bar, depends on what rear end i go with.
after i get the car running and what not, ill probably do a bushing kit as well then ill be done, probably keep the stock sway bars.
autopower race roll bar with optional harness bar extension is already in the mail.
