MR2 Cherry Red Exhaust Manifold Problem!
Old Mar 17, 2005 | 12:08 PM
Love Doctor's Avatar
SOOFIERCE
Default MR2 Cherry Red Exhaust Manifold Problem!
What does it mean when my Exhaust manifold glows cherry red?
My EGT when I first start it is 6, but after driving it for 8 mins it climbs to 10.
At that point, the MR2 T hesitates under any boost and the exhaust manifold is red hot!
What gives here?
PEACE-
Old Mar 17, 2005 | 12:54 PM
BlackZ28's Avatar
ppssshsshhhhhhh
need more info... what are ur mods? how much are u boosting? manifold is glowing red cuz obviously its very hot. my friends mr2T used to do that, but only after running hard on the highway for a while. should of seen the flames coming out of it. twas awesome
Old Mar 17, 2005 | 01:12 PM
SOOFIERCE
Default Additional Info
Stock Boost.
Original Exhaust.
Air Filter
B.O.V.
Fresh Rebuild
No Smoke
If you drive it for about 10 minutes with no boost, you get a red hot glowing Exhaust manifold. If you boost up, then it get hot quicker. So, I'm not driing it right now until I figure this out dude. Also, the car runs 3/4 hot on the temp gauge. Don't know why?
No Coolant leaks
All coolant hoses replaced
Radiator fan turns on, but just for a few secs and at a very low speed
New water pump
New thermostat
How do I read my EGT gauge? It climbs to 12 in under 10mins.
Whats wrong with this new rebuild?
Old Mar 17, 2005 | 01:53 PM
Jap's Avatar
Jap
VTEC Out
Sounds like your timming is really retarded ...
Check base timming
Hondata saves lives
Old Mar 17, 2005 | 02:15 PM
SOOFIERCE
Default EGT Gauge: HOW TO READ? MR2 T
Ok,
What is a normal reading? When do I know something is wrong?
PEACE-
Old Mar 17, 2005 | 04:30 PM
Smileys 84Supra's Avatar
Runs good....Sometimes.
Alright for some reason your car is running really lean so you might have an intake leak somewhere. your injectors might not be firing right and dumping enough fuel. anything that could create a lean condition would cause your manifolds to glow red. even a minor intake leak could casue this. jsut keep that in mind in your diagnosis.
93 Touring RX7 LS6 "Bolt Ons" -Toy
92 Talon AWD Turbo -daily/snow car
Team Fail Racing
Boredom owns me.
its like negative penguin outside this is bullshit. -Angela
Old Mar 17, 2005 | 05:21 PM
SOOFIERCE
Default Whistling Intake
My car has a high pitch whistle coming from the throttle body. The sound seems to be INSIDE of the throttle body. My EGT gauge has been reading 15, which maximum on that gauge is 16.
This shit ain't right, dude! Any ideas?
Old Mar 17, 2005 | 06:37 PM
its an intake tract leak that is casuing more air into the system after the maf therefore casuing it to run lean becasue there is more air ggoing into the motr than the maf accounts for so it is getting way to hot.
Team Fail Racing
Boredom owns me.
Old Mar 17, 2005 | 07:16 PM
jabdrifter's Avatar
hachi roku in my bunghole
what he said
joke= try header wrap....harharharhar
IN GERMANY
SOON KUWAIT
THEN IRAQ.....AGAIN
BIG RED ONE 1/18 KILLERS FROM THE GROUND HOOAH
fuckin kickass
Old Mar 17, 2005 | 08:51 PM
Team Fail Racing
Boredom owns me.
