mafs
Old Mar 17, 2005 | 07:38 AM
dsmtuner's Avatar
gotta love the boost
Default mafs
how would i be able to trick my n/a mafs into not reading boost i was told there was a way, to do this without changing ecus and harnesses.
thanks
SVT F150
Old Mar 17, 2005 | 07:42 AM
SilverTurbo's Avatar
It's Alive!!!!!
Are u talking about the map sensor? So your check engine light won't come on.
-SilverTurbo has future plans in mind...
Old Mar 17, 2005 | 07:44 AM
dsmtuner's Avatar
no my mafs you know how the turbo mafs on 1gs are bigger then the n/a well thats cause of the boost issue. i was told i need to trick my mafs some way so it dosent read boost.
SVT F150
Old Mar 17, 2005 | 08:14 AM
DEATH ZEPPELIN's Avatar
previously SLOWBOOST
Why not get a bigger maf? Are you setting it up for a blow thru? Why would it read boost if you stick it on the intlet for the turbo, its just air.
SUCH IS THE RULE OF HONOUR.
Old Mar 17, 2005 | 08:19 AM
dsmtuner's Avatar
well the plugs are diffenrent sizes on the n/a and the turbo, so you dont think i will have a problem.
SVT F150
Old Mar 17, 2005 | 08:26 AM
I dont understand what your tallking about. How is the maf going to read boost unless you make it a blow thru, which you cant.
Old Mar 17, 2005 | 08:40 AM
dsmtuner's Avatar
ok maybe i was told wrong then, im just gathering info before i go and put it in. k i have 450cc injectors you think that will be fine im running a t3 with about 11 psi.
SVT F150
Old Mar 17, 2005 | 08:46 AM
I think you may want to look into swapping out mafs, the 1g turbo mafs are restrictive enough as it is.
Old Mar 17, 2005 | 08:48 AM
dsmtuner's Avatar
k thanks....
SVT F150
Old Mar 17, 2005 | 07:27 PM
Philly Blunt's Avatar
TR Balla Donor Supreme
hewloo
