View Full Version : Battery And Cap
DubDaze
03-10-2005, 05:25 PM
I got my subs hooked up the other day the 2 15" rockfords, and a new 760 watt pioneer amp for them. but when the bass hits when i have the cd player turned up to about 20 the amp will turn off for a sec untill i turn the sound down back down. so i hooked up the battery charger to the car and when the bass hits the charger drops down real far, and thats when the amp turns off..
I Guess i need to get a optima yellow top and idk about what cap to get ..? :dunno:
Thanks
Bumpin Expo
03-10-2005, 06:15 PM
does ur car stall when the bass hits? if not I dont think the amp should shut off. I could be wrong tho, never hard that happen before
adero
03-10-2005, 06:51 PM
i'd guess there's something wrong with the way your system is set up. Check to see if there is a protection light that turns on on the amp when it turns off
TBSpyder
03-10-2005, 09:29 PM
Considering you have a 10 year old VW, I'd first upgrade your battery to a red top and also upgrade your wiring from your alternator to the battery to ground to 4 gauge. If it still does it, you probably need a larger alternator.
DubDaze
03-10-2005, 09:39 PM
the amp dosent shut off the light stays on on the amp,
DubDaze
03-10-2005, 09:44 PM
Hmm i guess when i get a job ill look into buying the stuff to upgrade it all... right now im runnin 8 gauge power and ground wires from the battery to the amp. and all the wiring is right in the set up so i know its not that ...
Whats happening is the voltage is too low for the amp. Get a yellow top and upgrade your alt to battery line to at least 4 guage, or 0/1 if you can. See if that makes an improvement
DubDaze
03-11-2005, 03:23 PM
yea i just found that out from other sites. but wont i need a cap to even if i get a yellot top and alt? j/w
Not likley. More often than not, capacitors are useless if you have the proper equipment in place. Good wiring, good connections, terminals, etc. I've never had a cap in ANY installs.
DubDaze
03-11-2005, 03:48 PM
ok , now i need to get a job to get those :)
You should still do the wiring for the time being :) its the cheapest one
DubDaze
03-11-2005, 04:47 PM
from the alt to the battery?
DubDaze
03-11-2005, 04:51 PM
what kinda amps would i need for the alternator?
You have to determine the total wattage you will be running. and yes alt to battery
Content Relevant URLs by
vBSEO 3.2.0 RC5
