da teg bumper
Old Mar 3, 2005 | 11:56 PM
dohcvtec's Avatar
You boys like Mexico!!!
Default da teg bumper
i need help on taking off a da integra front bumper
thanks
-sickofalltezzas
Springhill
22" Nothing less
Old Mar 4, 2005 | 12:40 AM
lowoctane's Avatar
Professional Dumbass
if i remember correctly, the main bolts should be behind the bumper lights/turn signals...everything else should be as easy as cutting cheese/
Itz jus' fo deckarayshunz man jus' fo deckarayshunz
Old Mar 4, 2005 | 12:46 AM
SickOfAlltezzas's Avatar
ALUMINUM POLISHER
so take out the turn signals and the headlights and go from there? what about the back?the only reason im asking is so i have some kind of idea before i go and look to pull it off without having an idea where shit is,keep me posted.thanks
Originally Posted by 240Cyanide
TR's better anyways.. where else could you find all this variety of assholes, drug specialist, and pedo's? not on that gay dsm site!
Old Mar 4, 2005 | 12:53 AM
lowoctane's Avatar
well i htink you wont be able to take out the headlights with out taking off the bumper...the bumpers are sorta like the accords, there should be atleast 2 bolts behind each bumper light, take those out, and the rest should be on the outer of the bumper its self, after removing those bolts, it should go fairly smooth on what needs to be takin out next.
Old Mar 4, 2005 | 05:11 AM
BitbyStreetRacin's Avatar
once your bit, your done.
Theres a shitload of 10mm bolts! You have to take out the headlights before you can take off the bumper, youll need a really long 10mm extension and on each side of the car, there will be a bracket holding each headlight to the radiator support. Those are the two hardest bolts to reach on the da headlights. But yea, take out the corners, the center foglights, etc. Theres gonna be about 5-6 10mm bolts to each headlight. THEN you can get the philips screws holding the bumper on which there is also a shitload of, like 7-10 of those screws. After all that the headlights and bumper cover should come off.
Are you installing/taking out the jdm headlights?
