PDA
View Full Version : welding a diff
zenki_s14
01-19-2005, 09:11 AM
who can weld a diff!?!?! cuz i wanna be hardcore like my hero funk! j/k
but i do wanna be hardcore!
sucio
01-19-2005, 09:59 AM
its like a fortune cookie you have to say INTO A POLE
zenki_s14
01-19-2005, 01:41 PM
i dont wanna be hardcore with a pole imprint in my quarter panel.... i wanna be hardcore with a welded diff....
can someone do this anymore or is it a lost art?
Mars_302
01-19-2005, 01:47 PM
In the end, it would be cheaper to buy a real diff.
sidehappyside
01-19-2005, 01:49 PM
really, how is it cheaper? i haev a welded diff, and i can weld yours zenk s14
TNathe
Just yank that biatch out and take it to a ANY welding shop that knows how to weld. Tell them to such and such together then go get some McDonald's, go back and pick up your diff, then install it back on teh car. Anyone who knows how to weld and what to weld on the diff can do it.
Philly Blunt
01-19-2005, 02:37 PM
xat did mine for 60 bux.............. excellent welding grade A+
mranlet
01-19-2005, 03:45 PM
Anyone ever braze one with Oxy-Acetelene? Brazed joints are often stronger than wire welded as long as there is suffecient overlap. Maybe it might prevent braking?
zenki_s14
01-19-2005, 04:17 PM
i knew you was the guy i was looking for... pm sent
TNathe
01-19-2005, 04:33 PM
All depends on the base metal. Welding FUSES and adds a filler metal, brazing adds a filler metal with bonds the two pieces. As thick as those damn gears are, you need hella heat and penetration to fuse them together. Where did you get your source of info at?
mendozasport
01-19-2005, 08:45 PM
once you braze together the metals the amount of heat needed will untemper the satelite gears causing them to crumble like cookies when force or torque wich ever one you prefer is applied, also when you take the diff apart mark everything on wich side it came off of and put it all back together the same way it came out or excesive noise will occur, i meen EXCESIVE noise...i have a 5 bolt diff from a j30 if you want it .....
zenki_s14
01-21-2005, 02:21 PM
i currently have a 6 bolt j30 diff in my car.........
but its not hardcore enough for me.....
and has less than 80thousand miles on it from a 97 j30 if anyone is interested......
TNathe
01-21-2005, 04:34 PM
what are you asking for it? I know of someone who should be interested.
zenki_s14
01-22-2005, 08:36 PM
225?
