PDA
View Full Version : Thinking about buying a SRT-4.
keith455
01-18-2005, 11:21 PM
What should I look for? Is one year better then others?
Also, is there anyone in the Riverview/Brandon area that would let me look at their car as Brandon Dodge doesn't have any in stock.
Sorry if this has been discussed before, but the search wasn't working at the time of this post.
Thanks
Skittle
01-18-2005, 11:55 PM
The 03's and 04/05 Models are Different...
03's came with i think 215hp,no LSD,smaller injectors...
04/05 models carry a LSD,bigger injectors,different ecu program,and 235hp...
And just check everything you would normally...
quickcivic
01-19-2005, 09:33 AM
Get an 05' or and 04' - Don't get one that is already modded. People beat these cars up!
Excellent car to get - great bang for the buck!
Josiah
01-19-2005, 09:39 AM
I have a 2.4 in a 1st gen, so I will clear this up...yes, you can swap a SRT motor in....but you CANNOT use the stock computer, as was mentioned, the crank trigger setup is different, you must either use a standalone, or do some funky wiring with the SRT4 computer, that being said, its not worth it, just get another 2.4 spend $250 for some SRT internals, buy an SRT turbo and intercooler and voila you have a motor just as good for a lot less, as far as the stock neon tranny not being strong enough, thats complete BS, these trannys have been proven to hold over 500HP quite easily...its the clutch thats the weak point, for my motor I am using wiseco forged pistons, T2 rods, pretty large FMIC from jonnyracecar, running about 8 psi for now until I get my standalone(been having problems with the stock NA computer and potentiometer setup) I'm even using the stock 2.0l clutch for now, its held up suprisingly well to the abuse of around 220HP(when its actually functioning...stupid NA computer) but I plan on upgrading to a decent clutch, some stronger axles and an LSD later, in other words...very possible, but the SRT motor is about the most uneconomical way to go...only way to go that way is if your afraid to build a motor yourself, or if you just lack the skill
Back-n-Black
01-19-2005, 01:51 PM
get a 2004 best parts peices stock and built. They have bigger axles to take punishment, bigger injectors for more fuel, LSD ot tourqe biasing diff, and you can get them new or low miles used. 05's do not have all the staged upgrades done yet and no one knows what all the computer changes are.
GsEclipse02
01-19-2005, 05:58 PM
dont buy a used srt every 1 beats the hell out of the str4s.... just my .02
adrian_302
01-19-2005, 06:09 PM
dont get an 03 unless you like spinning your tires. get an 04 or an 05
Skittle
01-19-2005, 06:34 PM
I spin till 60-70mph and i have a 04 :-( :lol:
neondriver
01-20-2005, 12:22 AM
the newer the better, dont buy them used!!! its asking for trouble, my friend just got one and with less than 3K miles he already beats the hell out of it. 04 are better than 03's, 04 stock have stage 1 injectors. Whats wrong with the 2.4 neon? a 2.4 turbo in a 1st gen will haul ass and beat alot of srt-4's. unless you want something fast, new, nice,cheap and with warrantee 04, 05 is choice.
adrian_302
01-20-2005, 05:03 AM
thats cuz youre t3h secks :)
Sourskittle
01-24-2005, 03:22 PM
I have a 04' and with just a MBC it spins the crap outta the BFGs.. Witout the MBC I was like " wonder why everyone complains about traction, mine hooks-up fine". Turns out the ECU sets the boost a little lower in 1st gear, now with 18psi, its pretty much as bad as my civic, just more predictable and stable.
I gotta admit, I never thought a neon would be stable at high speeds, but its very sable IMO.
The entire drivetrain doesn't seem to have a week point. Many 400++ Whp SRT4s are driving around... I'm happy with 250+ FT./lbs. of torque...
Bought mine for around $16K with 4600 miles on it. $5K discount for 4600miles, that's fine with me. Its not really possible for anyone to drive the car harder than I do, so whats the difference ? I've put almost 500 miles on the oil in it, and its about time to change it. I think these cars are VERY capable of getting there asses kicked daily, but ya just gotta take care of it ( IE: change the oil very often, and don't try to go too long on tranny fluid, and other stuff like that ).
