PDA
View Full Version : Blowoff valve
Srt4Viper
01-12-2005, 01:55 PM
Hey guys, I was wondering what type of blowoff valve you would suggest for my srt. I've been looking around and i dont really know much or every part that i ahve to get. Let me know what you guys think or what ones you guys ahve (don't wanna be a copy cat though).
BrYaN H
01-12-2005, 03:04 PM
i just got mine last week i think im gonna get the greddy type s
cali
01-12-2005, 06:10 PM
if you're stock the mopar will be fine.
running a lot of boost? Maybe something that can vent a lil faster.
keep in mind the mopar valve is sufficient to run the stage III kit making ~350whp
Josiah
01-14-2005, 10:47 AM
I'm using a 1st gen DSM BOV, but then I dont have a SRT4 either, I have a built 2.4 in a 1st gen, couldnt beat the price though $7 at cophers...heh...with mods good for holding up to 30psi (just crushing it you can hold 22)
Skittle
01-14-2005, 04:13 PM
i plan on using the tial soon,but for now at 18/19lbs the mopar bov is fine :-)
Srt4Viper
01-14-2005, 04:19 PM
So do you really like ur mopar one and is it loud i was thinking about getting it def worth the money. wahts ur overall views on it
Skittle
01-14-2005, 04:25 PM
i personally like mine,i can control it not to do the PSHHH noise everywhere(easy off the gas :-D )...but if your looking for a noise go with it,not really no performance from it...but it works as good as others :-)
GsEclipse02
01-15-2005, 07:27 PM
is the 2.4 a 420a engin????
neondriver
01-16-2005, 10:21 PM
the mopar sounds good, my friend has one on his srt-4 and i have one going on my car soon, you can get them used with all the parts for around $35 and their easy to install
Skittle
01-17-2005, 12:58 AM
Neondriver-are you using a stock Srt-4 turbo?..
Josiah
01-18-2005, 10:42 AM
well, the 2.4 has the same crank trigger setup as the 420a(which by the way is only in the NA eclipse and avenger, the DOHC neon has the same block, but the head is reversed and somewhat bettter flowing) the 2.4 is a different block....but yes, you could swap a 2.4 into your NA eclipse if you used the eclipse head, you would probably have to figure out something for the passengers side motor mount though, but all your other mounts should bolt up(could be wrong about this, have only done the swap in a neon, but I read about someone doing it in a NA eclipse), you would need to use a 2.4 from a pre 2001 stratus/cirrus/sebring/caravan for your eclipse head to bolt on and you would also need to reverse your coil leads, but other than that its a direct swap(for the neon)
p.s. sorry for getting off topic guys
fresh&clean
01-22-2005, 05:11 PM
My friend mike he has a silver 05 srt4 with a mopar bov sounds good I like it better then the greddy ones they sound like canaries.
neondriver
01-23-2005, 12:07 AM
Yes, out of an 04
