View Full Version : spring rate?
Philly Blunt
01-08-2005, 12:53 AM
what spring rate do you prefer for drifting? front and rear
Clifford
01-08-2005, 12:56 AM
stiff...that is all
what do you mean?!?! on coils/ or just by springs?
Philly Blunt
01-08-2005, 01:07 AM
like you know how the coil usually has a weight stamped on them what do you prefer and how much is stiff like 450 up front?
Philly Blunt
01-08-2005, 01:19 AM
Originally posted by Chin180sx
10kg frong 8 kg rear ahhh wtf lol i only know pounds
n2ocamry
01-08-2005, 01:22 PM
mny corolla runs great on 6 kg front 4.6 rear
marks accord had like 8kg in the front with 7kg in the rear
not that many springs for imports come in pounds
to better your knowledge you should learn how to convert-you will need it in the long run
Epstein
01-08-2005, 04:17 PM
10k is short hand for 10kg/mm. To convert to pounds, multiply by 56 to get lbs/in.
Some of the stiffest replacement springs are RSR Race, which are 5k front 4.5k rear. A company called KGMM makes stiffer springs, but they are really hard to come by.
Of course you can go higher with coilovers. The popular Tein HE's are 8k/6k. Increasingly popular Silk Roads go 9k/7k or higher. The pro D1 drivers actually run lower rates, around 7k/5k or 7k/6k. All of these rate that I have quoted are for S13.
aphxero
01-08-2005, 07:21 PM
LBS?
okay
350lb front
250-300 rear
But for a heavy assed car like the 240 I'd probably add 50lbs to each.
P_Productions
01-09-2005, 11:59 AM
12K in the front and 10K in the rear......They're also for sale
Content Relevant URLs by
vBSEO 3.2.0 RC5
