PDA
View Full Version : please read i need help fast
n2ocamry
12-22-2004, 01:12 PM
okay major problem with my ecu system
i turn on my 4ag ae86 yesterday, drive straight for 3 blocks then turn left. my car shuttered, i drove another 2 blocks straight then it died as i slowed for a stop sign. it wont turn back on.
the charge light and battery light on the dash are on as the key is in the on position, but the engine light is not....the engine light is supposed to be on
i put in a new igniter and ecu and the light still will not go on nor car start.
the car cranks but does not turn on
when i put the key to the on position also the idle speed control valve near the maf sensor clicks bad
what can this problem be
my wiring is in really good condition and i couldnt find a accidental ground or burned wire anywhere
i cant figure it out
also a couple of days ago my injectors became quite loud and still were up to this happen
i brushed the bad injector idea though cause it has nothing to do with the ecu engine light not coming on
if you know what the hell happened or have an idea please give
im desperate
thanks
jace
Idealsupra
12-22-2004, 01:29 PM
i know this sounds stupid... but did you check the EFI fuse? is thats burnt out the car wont start nor will you have a check engine light....
worth a shot...
aphxero
12-22-2004, 04:05 PM
I'm coming over... Be home.
MR-2
12-22-2004, 06:40 PM
cars don't like you either
n2ocamry
12-22-2004, 11:58 PM
yes everything has been checked
including the entire wiring harness
spent 6 hours today goin through each wire of my harness
found a melted wire.... replaced...... still didnt do anything
new ignitor
new ecu
new fuses
new relays
corrected timing and cam placements
fucked with dizzy
still nada
cant figure it out
im just gonna throw in a megasquirt
if the car still doesnt start ill throw in a redtop
if it still doesnt start im gonna have to get it professionally race wired - which hopefully will cut down on the wire quantity by more than half
if it still doesnt work im gonna set it on fire and piss on the ashes
