PDA
View Full Version : monitor (tv) question
stangerang
10-25-2004, 01:30 AM
i just put a tv in and its getting a little bit of static when the car is runnin but not when it is just on.........
its not a ton of static but just a little.........
anyway, my question is, so you think it is the actual monitors power supply getting interferance or the dvd player?
the sound quality is awesome so i dont think its the dvd player but i could be wrong.........
anyway, what can be done to solve this........ is there a coil you can use for the tv or something like that???????
93ex
10-25-2004, 07:04 AM
The video signal is very sensitive to any electrical interferance, and even feilds will cause issues..
stangerang
10-25-2004, 08:10 PM
i just figured its some type of static signal in the power supply.......
most tv's i've seen do what i am talking about........ i just wondered if there is any easy fix to this.......
its not a constant static, just every once and a while the tv will kinda flicker a few little lines across it, its barely noticable, but it doesn't do it the least little bit when the engine is off........
eli
10-25-2004, 09:29 PM
did u make sure to get video rcas? or just regular audio ones cause that could be a problem. i know i get a little static on one of my tvs cause its running along side of my power cords and shit hopefully i fixed that when i rewired .
stangerang
10-25-2004, 09:50 PM
they came with the TV so i think they are video ones
TBSpyder
10-25-2004, 11:40 PM
Try better cables.
stangerang
10-28-2004, 12:18 AM
see, i think its coming from the power source, not the signal source.........
i mean, its just crystal clear when the car power is on, but it gets that lil tiny bit of static when the motor is runnin........ so i think its the power signal,
bascally, how do you run a cleaner power signal.........
in fact i'll guarentee its the power cuz when the signal output is off but the monitor is on you can still see the lil fuzz every once and a while.......
should i try running a dedicated line to it? i have it running off the power accessory now........
