PDA
View Full Version : Rookiee needs help....Just got 1 kicker solobaric 10-inch
integraboi1010
10-11-2004, 01:15 PM
I built a custom box for this solobaric..but its not kicking at all....I know I didn't give it much airspace.....which could be a problem???.....could I drill some holes to help with the airspace or just build a bigger enclosed box.
93ex
10-11-2004, 02:15 PM
if the box is too small it will restrict the movement of the sub, and the ability to even make noise. BUT for it to be totally quiet the box would have to be rediculously small, and horribly underpowering the sub.
is it playing but jus tnot very loud?
integraboi1010
10-11-2004, 02:32 PM
Its playing but not giving good bass at all.
93ex
10-11-2004, 02:35 PM
everything is good on the amp? gains proper, etc? ohm load?
adero
10-11-2004, 02:36 PM
did you just randomly make a box out of wood?? Look up the recommended air space you the subs, and make a box to spec.
integraboi1010
10-11-2004, 02:50 PM
ITs a brand new amp. Yes I made the box out of wood with LITTLE AIRSPAcE. If I drill holes on the box to give airspace....will this help?
Solar Specialist
10-11-2004, 03:07 PM
No, don't do that. How is everything setup? What exact sub is it (single/dual voice coil, how many ohms, etc)? And what exact amp do you have running it and how is it wired? As for the box, what are the dimensions of it?
MDIFYTD
10-11-2004, 03:17 PM
Definately don't drill holes in the box. You can try stuffing the box with polyfill it should help some.
What dimensions are the box. I tend to agree with everyone else... it's probably not entirely the box.
Solar Specialist
10-11-2004, 03:21 PM
I agree. Back in high school when I didn't know jack shit I just took 2 10s and made a huge box out of wood and hooked them up to a 2 channel amp. Had no clue you could even run 2 speakers off 1 amp or anything about ohms at all.
integraboi1010
10-11-2004, 03:23 PM
I dont have the exact dimension on the box right now....but its DEFINETELY small than KICKER recommendation. Anyone in St. pete or Tampa...can can look at my setup & box?
adero
10-11-2004, 03:24 PM
if you put pollyfill in the box, it will decrease the airspace, and it'll probably sound worse. just make a new box. Or tell us the model number, and we'll give you a simple design.
integraboi1010
10-11-2004, 03:31 PM
I got a kicker solobaric square L7 10".
adero
10-11-2004, 03:42 PM
minimum recommended sealed space is 2/3 ft^3 and max is 1 ft^3 so .85 ft^3 should be good. make it easy on yourself, and make the face 1' by 1'. and make if 15" deep. That is assuming that you use 3/4" MDF board. It will give you an internal volume of very close to .86, and the subwoofer should displace a little of that volume.
integraboi1010
10-11-2004, 03:53 PM
Wow...15" deep....mind only got 5 inches deep max right now...maybe that's the problem. What's teh differences between serial vs parrallel wiring?? I have an alpine 5-channel amp....was planning to run the speaker box with this amp.
MDIFYTD
10-11-2004, 04:03 PM
First off putting polyfill in a box slows down the air inside the box 'tricking' the speaker into thinking it's in a larger enclosure. Secondly, a 1'x1'x1.25' enclosure would be > 1 cube.
MDIFYTD
10-11-2004, 04:08 PM
What's the model of the amp? Also, is the sub dual 2ohm or dual 4ohm? Oh and can you get us the exact dimensions of the box?
integraboi1010
10-11-2004, 04:33 PM
Ok I'll get hte dimension for you guys tommorrow. The sub is a 4oohm I think.
adero
10-11-2004, 04:51 PM
not internal volume. 10.5" by 10.5" by 13.5" equals .875' by .875' by 1.125' and gives an internal volume of .861328125 ft^3. This is assuming that he uses 3/4" MDF board for the construction of this enclosure. Sorry you mis-understood me.
integraboi1010
10-11-2004, 05:03 PM
I got an alpine 5-channel amp with 800w. Speaker is 4omh i think.
the box demension is 12h * 6depth * 12width.
adero
10-11-2004, 05:05 PM
that box gives you an external volume of about .5 ft^3 what did you built it out of? What is the model number on the amplifier?
TBSpyder
10-11-2004, 09:23 PM
Sounds like too little air space and not enough power. You really need to put that sub in a box about 2 cubic ft. and give it atleast 400w rms to get it moving.
TIM TIM TIM
10-11-2004, 09:28 PM
+1.. to little air space. you deff. have no idea what your doing do you? lol
integraboi1010
10-12-2004, 02:06 PM
I got an ALPINE MRV-F450 V12 5-channel amp
Broadway
10-12-2004, 07:51 PM
would be best to get a mono amp, cuz that alpine will only put out about 200 RMS max, and you need double that
integraboi1010
10-12-2004, 09:10 PM
So if I get an apline amp that pushes 550 watts RMS x 1 at 2 ohms . It should be able to push my solobaric L7 10inch fine?
integraboi1010
10-12-2004, 09:12 PM
So if I get an apline MONO amp that pushes 550 watts RMS x 1 at 2 ohms . It should be able to push my solobaric L7 10inch fine? Or I need something in the 700-1000 watts range? I dont really like it super loud, just nice bass :)
Here's the spec for Kicker speaker:
RMS Power Handling 600Watts
Peak Power Range 1200Watts
Impedance ( Ohms ) Dual voice coils
Sensitivity 85.6dB
Frequency Response 24-0.1KHz
Cone Material Titanium-deposit poly
Surround Material Santoprene Rubber
And here's the spec for my current amp:
· 50 watts RMS x 4 + 200 watts RMS x 1 at 4 ohms
· 60 watts RMS x 4 at 2 ohms + 200 watts RMS x 1 at 4 ohms
· 120 watts RMS x 2 + 200 watts RMS x 1 in bridged mode
· 2-, 3-, 4-, or 5-channel output
· Tri-Way capable
· Requires 8-gauge power and ground leads
· MOSFET power supply
· STAR Topology (minimizes internal noise and prevents ground interference
· Oversized power and ground connections
· Gold-plated screw terminals
· Top-mounted controls with cover
· Detachable front cover
· Blue power LED
Broadway
10-12-2004, 09:29 PM
http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=13121
http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=14333
those should do you good, may wanna get opinions from other people frist tho...
adero
10-12-2004, 10:53 PM
how many ohms is your subwoofer?
integraboi1010
10-13-2004, 09:04 AM
Its a 4omh subs. But I can wire it to 2omhs.
93ex
10-13-2004, 10:50 AM
Its a 4omh subs. But I can wire it to 2omhs. If you have a DUAL 4 ohm sub, its not a 4 ohm sub. Your total load is either 8 ohms or 2 ohms.. perhaps you wired it to 8 ohms in the too small box?
integraboi1010
10-13-2004, 11:32 AM
Yea I know for sure I wired it wrong...I need to rewire it to 2ohm. But do you think I can run my 200watts at 2omhs for this sub? Or get a new amp?
93ex
10-13-2004, 01:55 PM
i dont belive that the alpine 5 channel amps support running at 2 ohms for the sub output. So I would say new sub or new amp. new sub might be a better idea imho
integraboi1010
10-13-2004, 02:06 PM
Would 550 watts 2ohm amp be ok to push this sub?
Broadway
10-13-2004, 04:29 PM
that should be enuff
make sure its 550 Wats RMS and Not 550 watts max
Turbo GSR Civic 95
11-02-2004, 08:11 AM
it depends on what kinda bass you're looking for and how much you have to spend because probably your cheapest option would be to get rid of the solobaric and get like a kicker comp vr with dual 8ohm voice coils and run it 4 ohm mono on your alpine amp it would be enough power to make it sound good i have the same sub in my girls hatchback with a 2 channels bridged on a kenwood 50x4 amp and it play all kinds of music and has good bass response
XoCiViCoX96
11-02-2004, 11:32 AM
if u go 2 circut city with the problem on 19 in country side i can get u a 700 watt alpine amp with digital read out it was the display and 10 inch q logic box 165
