PDA
View Full Version : hmmm.... Normally doesnt burn THAT bad.....
FiReBReTHa
09-24-2004, 07:13 PM
Well im trying to cut a circle in half inch MDF with my dremel and DAYM, A shit load more smoke than im used to! i cut maybe.... half an inch. I was getting nowhere with it.
WTF is going on!
I want to get my doorpods in progress!
-rick
93ex
09-24-2004, 07:32 PM
dull bit
edit - assuming it was smoke form the wood, the bit is dull, and/or youre trying to mve too fast.. but it sounds like a dull bit.
FiReBReTHa
09-24-2004, 07:58 PM
hmm. dammit. I tried four diff ones I had that are for flat board cutting. To the hardware store I go!
Pics to come as things get done, Burnt, blown up, etc.
TBSpyder
09-24-2004, 08:09 PM
Why are you using a dremel? Use a jigsaw.
FiReBReTHa
09-24-2004, 08:21 PM
Originally posted by TBSpyder
Use a jigsaw.
Lack of.
Down here I have Nothin!
all I have is a dremel and a craftsman toolbox. :(
adero
+1. just try to make the cut smooth. i usually end up moving back and forth on the line when i use a jig saw.
93ex
09-24-2004, 08:30 PM
I used to be shakes mcgee with the jigsaw back in the day.. practice..
FiReBReTHa
09-25-2004, 09:41 PM
stuck with the dremel, I was putting the board device on the end, but i sized it to 1/2 inch.
silly, instead i allowed the drill bit to go ALL the way thru so the board is closer to the actual dremel so its more sturdy, I then jacked the speed to max and was good to go! more pics of what im doing in the forum
