PDA
View Full Version : setup question
adero
09-19-2004, 09:07 PM
I have 2 image dynamics subwoofers, and a rockford fosgate amp, and i'm trying to figure out if/how i can hook them up. The subs are the IDQ V1 series and are SVC 4 ohm with an RMS of 200. the amplifier is a 400s and is rated at 400 watts bridged at 4 ohms.
how to i wire it all?
Bumpin Expo
09-19-2004, 09:23 PM
the only way I know to wire those subs...your going to need an amp thats going to put out max power at 2 ohms
http://www.maaudio.com/sub/techsupport/boxparameters/image003.gif
=2 ohms with two SVC 4 ohm subs
adero
09-19-2004, 10:34 PM
that's gay, i thought i could wire the subs to 4 ohms somehow
TBSpyder
09-19-2004, 10:58 PM
Series. You could run them down to 2ohms..but I've found RF amps get extremely hot while that low.
adero
09-19-2004, 11:20 PM
so i need a different amp?
GsEclipse02
09-20-2004, 05:10 PM
my fosgate amp dose get very hottt but its never over heatd
TBSpyder
09-20-2004, 10:12 PM
No.
adero
09-20-2004, 10:32 PM
Originally posted by TBSpyder
No.
the amp is 400 watts at 4 ohms, does it matter that the subs will be hooked up to the amp at 2 ohms?
93ex
09-20-2004, 10:52 PM
not really.. since it wil lbe in 2 ohms, the wattage will jump, so you acommodate with the gain
adero
09-25-2004, 08:59 PM
would this (http://www.tamparacing.com/forums/showthread.php?threadid=183090) amp work with my subs? it's bridgeable to 200 watts rms at 4 ohms, so the subs should see 400 watts at 2 ohms right? Would the amp over-heat?
93ex
09-26-2004, 04:28 AM
MTX Thunder421D
93ex
09-26-2004, 04:29 AM
Coustic 401DB
adero
09-27-2004, 09:11 PM
does 200 rms at 4 ohms always give 400 at 2? Two people on TR are selling mtx amps that are like that. Would i have to worry about them over-heating?
GsEclipse02
09-27-2004, 11:00 PM
im going to have to say no because that would mean 400 watts at 4 ohms would be 800 watts at 2 ohms and thats not always tru
adero
09-27-2004, 11:07 PM
the way i understood it, it went something like this:
100 @ 8 ohms
200 @ 4 ohms
400 @ 2 ohms
800 @ 1 ohm
GsEclipse02
09-27-2004, 11:12 PM
if its an mtx it dosent go down to 1 ohm stabel will over heat or catch on fire seen it happen
adero
09-27-2004, 11:17 PM
I was just using it as an example. But should it be able to handle a 2 ohm load?
GsEclipse02
09-27-2004, 11:53 PM
yea most amps will its when its like 1 ohm or half an ohm were it becomes a problem
93ex
09-28-2004, 12:35 AM
a lot of 2 channel amps dont like bridged to a 2 ohm load
