View Full Version : IDQ sub which amp to power it?
Sam_I_am
08-27-2004, 03:09 PM
I was thinking of getting one Image Dynamics IDQ12 D4 V.2 (http://www.cardomain.com/item/IDSIDQ12D4V2) sub for the price, the good reviews and the compact box volume requirements.
Now I can't decide one which amp is best suited for this sub. I have the following choices:
Alpine MRP-M350 (http://www.crutchfield.com/S-gGtP64vsbSN/cgi-bin/ProdView.asp?s=0&c=3&g=130&I=500MRPM350&o=v&a=0&cc=01&avf=N&search=) 350 watts RMS x 1 at 2 ohms
Kicker KX400.1 (http://www.cardomain.com/item/KIC04KX4001) 400W x 1 @ 2 ohms
Which amp would you guys recommend?
if those were the choices id get the kicker.
Sam_I_am
08-27-2004, 03:42 PM
what else would you recommend?
arc audio... Id prolly put a jl 500/1 on it...
Miles
08-27-2004, 04:28 PM
add DLS to that list... a little cheaper than ARC and just as good if not better (from what i hear... i've never owned an arc amp)... of those two choices i'd go with the kicker, that amp will power it just fine.
TBSpyder
08-27-2004, 10:21 PM
I'll second ARC, great quality...probably twice as much as the amps you listed though.
Clifford
08-28-2004, 03:17 PM
or you can buy my complete setup
2-12" alpine type e's and sealed box
1-rockford 500bd amp pushing 670wts, never at full power, has bass controller
all wiring...
325?
Sam_I_am
08-28-2004, 11:32 PM
well i'm puting this behind the 3rd row seat in a land cruiser and space is limited to about 13 inches deptwise..
and im located in palm coast, 30 miles north of daytona so i can't pick it up.
adero
08-31-2004, 03:31 PM
check out this (http://www.mmxpress.com/id.html) place. they got the idq12 for 160 and free shipping. Image dynamics subwoofers are awesome. My brother has two idq10s that i built a box for, and they are some of the best i have ever heard.
You should look into an amp that has a remote gain so that you can turn off the sub if need be. It helps when there are cops around and stuff.
MDIFYTD
08-31-2004, 03:40 PM
ARC 2100cxl
In fact I ran that exact setup for a little while, after my previous sub amp burned up, sounded pretty darn good!
TBSpyder
08-31-2004, 06:28 PM
Remote gain is a worthless toy really. Most decks nowadays have built-in sub controls. And if for some reason you ever wanted to cut the sub off, you could always wire a simple switch into the remote turn-on for the amp.
or just turn the volume down
TBSpyder
08-31-2004, 11:53 PM
:lol: But that's too easy!
adero
09-01-2004, 12:14 AM
but then i can't hear it anymore. idk, i'm just screwed up, and would rather turn my sub down a little while i drive by a cop or something. And i like to be able to easily change the bass level depending on the song that i am listening to. it's just easier for me to use a gain.
TBSpyder
09-01-2004, 12:41 AM
I think remote gains could be better referred to as "distortion knobs." :lol:
Miles
09-01-2004, 12:53 AM
i <3 idq's
that is all
Jordan Y.
09-01-2004, 05:25 PM
But that's a misuse of the gain controls. As I understand it from bcae1.com, a gain is used to match the output of the head unit with the amp so that the max output of the amp or the max output the speakers can take is reached at a certain volume level on the head unit, usually around 3/4 of the way to full. The only time you'd want to use it as a "volume control" is when you've properly set the gains for, say, the fronts and subs and one is overpowering the other, in which case you can turn the louder speakers' gain down.
Sam_I_am
09-01-2004, 08:57 PM
well i just ordered 1 IDQ12 d4 v2's and the kicker kx400.1 amp. should be here next wednesday. i hope it sounds good!
Content Relevant URLs by
vBSEO 3.2.0 RC5
